Hello all!
Anyone have any info on integrating the new Enklov wifi DIY alarm system? Its a badass full featured DIY alarm system with self monitoring and cloud access. Would love to integrate this.
Hello all!
I could not find anything to indicate that this system has any sort of API. Someone would have to reverse engineer it, assuming that the communications between the system and the Enklov servers is not encrypted. Of course if that is the case I would say you should NOT be using this system under any circumstances.
Yea, Not getting a whole lot of useful data. Its talking to amazons aws cloud tho anyway.
ec2-54-164-160-216.compute-1.amazonaws.com.1883 > 10.1.100.210.45079: Flags [.], cksum 0xb47f (correct), ack 900, win 65392, length 0
E..(..@.....6...
.d..[.....%..\IP..p....
21:51:13.514841 IP (tos 0x0, ttl 128, id 960, offset 0, flags [none], proto TCP (6), length 42)
10.1.100.210.45079 > ec2-54-164-160-216.compute-1.amazonaws.com.1883: Flags [P.], cksum 0xdfdb (correct), seq 900:902, ack 51, win 5130, length 2
E..*........
.d.6......[..\I...%P..
21:51:13.559364 IP (tos 0x0, ttl 234, id 47635, offset 0, flags [DF], proto TCP (6), length 40, bad cksum 0 (->906c)!)
ec2-54-164-160-216.compute-1.amazonaws.com.1883 > 10.1.100.210.45079: Flags [.], cksum 0xb47d (correct), ack 902, win 65392, length 0
E..(..@.....6...
.d..[.....%..\KP..p.}..
21:51:13.560688 IP (tos 0x0, ttl 234, id 47636, offset 0, flags [DF], proto TCP (6), length 42, bad cksum 0 (->9069)!)
ec2-54-164-160-216.compute-1.amazonaws.com.1883 > 10.1.100.210.45079: Flags [P.], cksum 0xe472 (correct), seq 51:53, ack 902, win 65392, length 2
E..*..@.....6...
.d..[.....%..\KP..p.r....
21:51:13.574131 IP (tos 0x0, ttl 128, id 961, offset 0, flags [none], proto TCP (6), length 40)
10.1.100.210.45079 > ec2-54-164-160-216.compute-1.amazonaws.com.1883: Flags [.], cksum 0x9fe4 (correct), ack 53, win 5128, length 0
E..(........
.d.6......[..\K...'P.............
21:51:29.525393 IP (tos 0x0, ttl 128, id 967, offset 0, flags [none], proto TCP (6), length 44)
10.1.100.210.14930 > ec2-52-91-110-32.compute-1.amazonaws.com.1884: Flags [S], cksum 0xed83 (correct), seq 278738, win 5840, options [mss 1460], length 0
E..,......%.
.d.4[n :R.\..@.....`.............
21:51:30.349101 IP (tos 0x0, ttl 128, id 968, offset 0, flags [none], proto TCP (6), length 44)
E..,......%.
21:51:31.348166 IP (tos 0x0, ttl 128, id 969, offset 0, flags [none], proto TCP (6), length 44)
E..,......%.
21:51:32.352097 IP (tos 0x0, ttl 128, id 970, offset 0, flags [none], proto TCP (6), length 44)
E..,......%.
21:51:33.348309 IP (tos 0x0, ttl 128, id 971, offset 0, flags [none], proto TCP (6), length 44)
E..,......%.
21:51:34.398148 IP (tos 0x0, ttl 128, id 972, offset 0, flags [none], proto TCP (6), length 44)
E..,......%.
21:51:35.424342 IP (tos 0x0, ttl 128, id 973, offset 0, flags [none], proto TCP (6), length 44)
E..,......%.
