Hi there,
I’m using openhab3 and the EnOcean binding. My goal is to control the ventilation system in my house. The EEP D2-50-00,01 is currently not supported by the binding, therefore the fallback “genericThing” is used but I cannot get it to show any data whatsoever.
This is the thing configuration, all devices are listed as online.
Bridge enocean:bridge:gtwy "EnOcean Gateway" [ path="/dev/ttyUSB0" ] {
Thing genericThing air_bad_og "Lüftung Bad OG" @ "Bad OG" [enoceanId="050ADC06", senderIdOffset=1, sendingEEPId="D2_FF_FF", receivingEEPId="D2_FF_FF", broadcastMessages=false, suppressRepeating=false]
Thing genericThing air_hwr "Lüftung HWR" @ "HWR" [enoceanId="050CD588", senderIdOffset=2, sendingEEPId="D2_FF_FF", receivingEEPId="D2_FF_FF", broadcastMessages=false, suppressRepeating=false]
Thing genericThing air_wohn "Lüftung Wohnen" @ "Wohnzimmer" [enoceanId="050ADD71", senderIdOffset=3, sendingEEPId="D2_FF_FF", receivingEEPId="D2_FF_FF", broadcastMessages=false, suppressRepeating=false]
Thing genericThing air_schlaf "Lüftung Schlafzimmer" @ "Schlafzimmer" [enoceanId="050CC375", senderIdOffset=4, sendingEEPId="D2_FF_FF", receivingEEPId="D2_FF_FF", broadcastMessages=false, suppressRepeating=false]
In the debug log I can see data being received:
2021-04-20 12:29:08.807 [TRACE] [ernal.transceiver.EnOceanTransceiver] - >> Received header, data length 20 optional length 7 packet type 1
2021-04-20 12:29:08.808 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - RADIO_ERP1 with RORG VLD for 050CC375 payload D24103000F00AD5000003C0F2281E6050CC3750000FFFFFFFF4D00 received
2021-04-20 12:29:09.301 [TRACE] [ernal.transceiver.EnOceanTransceiver] - Received Sync Byte
2021-04-20 12:29:09.302 [TRACE] [ernal.transceiver.EnOceanTransceiver] - >> Received header, data length 20 optional length 7 packet type 1
2021-04-20 12:29:09.318 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - RADIO_ERP1 with RORG VLD for 050CC375 payload D260D8124A00000000000000000000050CC3750000FFFFFFFF4D00 received
2021-04-20 12:29:36.032 [TRACE] [ernal.transceiver.EnOceanTransceiver] - Received Sync Byte
2021-04-20 12:29:36.033 [TRACE] [ernal.transceiver.EnOceanTransceiver] - >> Received header, data length 20 optional length 7 packet type 1
2021-04-20 12:29:36.033 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - RADIO_ERP1 with RORG VLD for 050ADC06 payload D24103000F009D4800003C0F21620A050ADC060000FFFFFFFF4A00 received
2021-04-20 12:29:36.528 [TRACE] [ernal.transceiver.EnOceanTransceiver] - Received Sync Byte
2021-04-20 12:29:36.529 [TRACE] [ernal.transceiver.EnOceanTransceiver] - >> Received header, data length 20 optional length 7 packet type 1
2021-04-20 12:29:36.545 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - RADIO_ERP1 with RORG VLD for 050ADC06 payload D260D8124A00000000000000000000050ADC060000FFFFFFFF4A00 received
I tried adding an item to the genericString
channel but the value is always NULL
. I also tried adding a JS
mapping with some dummy function which just returns the data as string but I still only see NULL
Am I missing something here? My assumption was I can receive the raw data in the JS map and transform it into something usable but to my it looks like the map is not even called.
