Clean new installation for this testings!
openhab-distro : 2.4.0.M8
smarthome : 0.10.0.oh240M8
openhab-core : 2.4.0.M8
openhab1-addons : 1.13.0.M8
openhab2-addons : 2.4.0.M8
karaf : 4.2.1
Only EnOcean Binding installed, NO other stuff next to the default installation.
Dear Daniel
Thank you for your feedback, suggestions and help offer.
I did try as you and @vzorglub did mention.
Unfortunately I wasn’t able to get any of my devices to work through the “xxx.things” file way.
I did try the following configuration.
Bridge enocean:bridge:gtwy “EnOcean Gateway” [path="/dev/serial0"]
{Thing measurementSwitch dim_wozi_standlamp “Omnio Aktor (EEP D2_01_01)” @ “TEST” [
enoceanID=“0190D273”,
senderIdOffset=3,
sendingEEPId=“D2_01_01”,
broadcastMessages=false,
receivingEEPId=“D2_01_01”,
suppressRepeating=false,
pollingInterval=300]
{Thing measurementSwitch dim_wozi_standlamp “Omnio Dimmer (EEP D2_01_03)” @ “TEST” [
enoceanID=“018D1393”,
senderIdOffset=4,
sendingEEPId=“D2_01_03”,
receivingEEPId=“D2_01_03”,
{Thing measurementSwitch dim_wozi_standlamp “Omnio 2 Kanal Aktor (EEP D2_01_11)” @ “TEST” [
enoceanID=“01918048”,
senderIdOffset=5,
sendingEEPId=“D2_01_11”,
receivingEEPId=“D2_01_11”,
Except the “EnOceanId”, all other parameters have been acepted through the xxx.things file.
Next to the added thing I see the following error message in the PaperUI: “UNINITIALIZED - HANDLER_CONFIGURATION_PENDING”
If I add the EnOceanId “” manually, in the rigth lower corner of the PaperUI I see failure “Error 409 Conflict”.
In the log I can see the following:
[hingStatusInfoChangedEvent] - ‘enocean:measurementSwitch:act_d2_01_01’ changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
[hingStatusInfoChangedEvent] - ‘enocean:measurementSwitch:dim_d2_01_03’ changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
[hingStatusInfoChangedEvent] - ‘enocean:measurementSwitch:act_d2_01_11’ changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
After long tries and errors I gave the PapierUI a last chance to use the “Inbox” and after starting it with the EnOcean Bridge, went through “ADD MANUALLY” and filled in the required data.
This time I was able to integrate the devices and they where working some how, at least the normal actuators (D2_01_01, D2_01_11). The dimmer (D2_01_03) didn’t react on any klicks at all.
But there is an more difficult failure with this EnOcean and Openhab 2 setup.
The switches of the singel actuator (D2_01_01) and the not responding dimmer (D2_01_03) do change there switch position without ANY interaction of my side.
The two channel actuator (D2_02_11) doesn’t show this behavior.
Also all of this EnOcean devices sometime do only physically switch from ON to OFF or viceversa after I did change the switches in the PaperUI two times in a row.
So, Is this somehow a
- known problem?
- something which I can solve?
- something I did setup wrongly?
What’s next to go on?
Which log file data do you need and how/where to get the right ones?
Thank you all for your feedback and response.
Regards and have a nice weekend
Thomas
