i have problems connecting my enOcean sensors to my server. The following error appears in openhab.log:
> 2019-12-06 09:34:29.364 [ERROR] [ernal.transceiver.EnOceanTransceiver] - Exception in informListeners
> java.lang.NumberFormatException: For input string: ""
> at java.lang.NumberFormatException.forInputString(NumberFormatException.java:65) ~[?:1.8.0_232]
> at java.lang.Long.parseLong(Long.java:601) ~[?:1.8.0_232]
> at org.openhab.binding.enocean.internal.transceiver.EnOceanTransceiver.informListeners(EnOceanTransceiver.java:423) [bundleFile:?]
> at org.openhab.binding.enocean.internal.transceiver.EnOceanTransceiver.processMessage(EnOceanTransceiver.java:313) [bundleFile:?]
> at org.openhab.binding.enocean.internal.transceiver.EnOceanTransceiver.receivePackets(EnOceanTransceiver.java:200) [bundleFile:?]
> at org.openhab.binding.enocean.internal.transceiver.EnOceanTransceiver.access$3(EnOceanTransceiver.java:192) [bundleFile:?]
> at org.openhab.binding.enocean.internal.transceiver.EnOceanTransceiver$1.run(EnOceanTransceiver.java:163) [bundleFile:?]
> at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_232]
> at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_232]
> at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:1.8.0_232]
> at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:1.8.0_232]
> at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_232]
> at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_232]
> at java.lang.Thread.run(Thread.java:748) [?:1.8.0_232]
My configuration:
CentOS 7 on VMware ESXi 6.7
Openhab2: Testing Version 2.5.0~M6
Java: zulu-8-8.42.0.23-1
enOcean USB300 Receiver
After manual adding the following error still occurs regularly in openhab.log:
2019-12-06 11:03:55.443 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - RADIO_ERP1 with RORG Unknown for payload 30B7E0FE27B3FB048D058E3CC30000FFFFFFFF5E00 received
2019-12-06 11:03:55.444 [ERROR] [ernal.transceiver.EnOceanTransceiver] - Exception in informListeners
Thank you so much. How can I understand that… can’t OpenHab handle the NodOn sensor? According to https://www.openhab.org/addons/bindings/enocean/ it is supported. Do I have to use the snapshot release?
your sensor is supported by the binding. However you should not try to do the teach in encrypted. Look here others had the same problems with NodOn sensors, but they can be setup to send unencrypted messages.
sorry I have not read the github status message correctly. My PR regarding this issue just got approved but not yet merged. I will create a new openocean version this weekend with all open branches merged.
I have got a similar error on enOcean binding 3.4.0 with a Rollershutter NodOn SIN-2-RS-01
The error is the following:
2023-01-01 18:57:39.920 [ERROR] [ernal.transceiver.EnOceanTransceiver] - Exception in informListeners
java.lang.IllegalArgumentException: Value must be between 0 and 100
at org.openhab.core.library.types.PercentType.validateValue(PercentType.java:93) ~[bundleFile:?]
at org.openhab.core.library.types.PercentType.<init>(PercentType.java:52) ~[bundleFile:?]
at org.openhab.binding.enocean.internal.eep.D2_05.D2_05_00.getPositionData(D2_05_00.java:88) ~[bundleFile:?]
at org.openhab.binding.enocean.internal.eep.D2_05.D2_05_00.convertToStateImpl(D2_05_00.java:122) ~[bundleFile:?]
at org.openhab.binding.enocean.internal.eep.EEP.convertToState(EEP.java:115) ~[bundleFile:?]
at org.openhab.binding.enocean.internal.handler.EnOceanBaseSensorHandler.lambda$3(EnOceanBaseSensorHandler.java:170) ~[bundleFile:?]
at java.util.stream.ForEachOps$ForEachOp$OfRef.accept(ForEachOps.java:183) ~[?:?]
at java.util.ArrayList.forEach(ArrayList.java:1541) ~[?:?]
at java.util.stream.SortedOps$RefSortingSink.end(SortedOps.java:395) ~[?:?]
at java.util.stream.Sink$ChainedReference.end(Sink.java:258) ~[?:?]
at java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:485) ~[?:?]
at java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:474) ~[?:?]
at java.util.stream.ForEachOps$ForEachOp.evaluateSequential(ForEachOps.java:150) ~[?:?]
at java.util.stream.ForEachOps$ForEachOp$OfRef.evaluateSequential(ForEachOps.java:173) ~[?:?]
at java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234) ~[?:?]
at java.util.stream.ReferencePipeline.forEachOrdered(ReferencePipeline.java:502) ~[?:?]
at org.openhab.binding.enocean.internal.handler.EnOceanBaseSensorHandler.packetReceived(EnOceanBaseSensorHandler.java:160) ~[bundleFile:?]
at org.openhab.binding.enocean.internal.transceiver.EnOceanTransceiver.lambda$0(EnOceanTransceiver.java:309) ~[bundleFile:?]
at java.lang.Iterable.forEach(Iterable.java:75) ~[?:?]
at org.openhab.binding.enocean.internal.transceiver.EnOceanTransceiver.informListeners(EnOceanTransceiver.java:309) [bundleFile:?]
at org.openhab.binding.enocean.internal.transceiver.EnOceanESP3Transceiver.processMessage(EnOceanESP3Transceiver.java:140) [bundleFile:?]
at org.openhab.binding.enocean.internal.transceiver.EnOceanTransceiver.receivePackets(EnOceanTransceiver.java:262) [bundleFile:?]
at org.openhab.binding.enocean.internal.transceiver.EnOceanTransceiver$1.run(EnOceanTransceiver.java:197) [bundleFile:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
