I’m new to openHAB. For testing purposes I have EnOcean Hardware:
USB300 EnOcean Gateway
RockerSwitch
Actuator (Omnio UPS230/08), i.e. a simple relay
I installed openHAB v1.8.0 on a Mac (OS X 10.11.2).
I succeeded with a basic setup: openHAB picks up EnOcean messages and (sometimes) shows the state changes in the web frontend. In the log I can also see those messages.
Thus, I conclude that communication with the EnOcean wireless Network basically works.
However, I miserably failed sending a command to the actuator.
That can have two reasons: a) configuration error, b) misinterpretation of how openHAB works. I actually suspect that the latter is the case (if not both).
Here are the lines from the .items file I tried but are not working:
Switch Switch1 “Switch1” (All) { enocean="{id=xx:xx:xx:17, eep=F6:02:01, channel=A}" }
Switch Taster1 “Taster1” (All) { enocean="{id=xx:xx:xx:5A, eep=F6:02:01, channel=B, parameter=I}" }
So, I’d very much appreciate if anybody could provide a very simple - but complete! - example:
Sensor -> openHAB -> Actuator. And that in terms of EnOcean components.
Did Your issue Resolve!?? Actually, I too facing the same issue. The openHAB is able to receive the Enocean RPS command from the Enocean Switch but not able to forward it to the Actuator/Actor. So I am not able to control the Actuator/Actor via openHAB.
Please let me know, if Your issue is resolved and How!
Thanks and Awaiting Your Response…
After a couple of hours tinkering with the rotary dial, I have finally managed to get my Omnio UPS 230/10 actuator working on OH2.5 along with USB300.
Set the Feedback Telegram type to VLD (D2-01-01): 15 LRN (2s) 12 LRN
Turn on OH2.5 autodiscovery (Scan for Things)
Set the Manual Feedback to Launch UTE teach in: 13 LRN (2s) 11 LRN
Energy Measurement Switch should show up.
Play around with the rotary dial to fine-tune your device settings (message frequency, etc.
