I use the ZWAVE-Binding with a Razberry. Can I use the EnOcean-Binding with a EnOceanPI (or USB 300) at the same time?
Yes, im doing exactly that. You can even add a zigbee stick to the mix and it will work. Just make sure to use symlinks when using multiple usb devices on a raspberry/ linux. you can find a few tutorials about symlinks on this forum if you search. If you dont use symlinks this can lead to a lot of trouble at least it did in my case
best regards Johannes
Thanks Johannes,
do you use only usb-sticks for that or also one or more serial devices?
usb sticks, one for zwave and the usb 300 for enocean
