davebuk
(Davebuk)
41
Yes, I’m feeding it into influxdb and can then use grafana to show charts etc.
I’m going to give this enphase to MQTT script a go at some point: GitHub - mcrapts/enphase-to-mqtt: Read solar production data from your Enphase Envoy gateway and publish on MQTT
I need to find some spare time to install and setup docker etc.
isoparme
(pol-henri Dupont)
42
this work too with version 7 ?
i have this error:
Requesting 'https://192.168.2.122/ivp/meters/readings' (method='GET', content='null') failed: org.eclipse.jetty.client.HttpResponseException: HTTP protocol violation: Authentication challenge without WWW-Authenticate header
davebuk
(Davebuk)
43
Yes it works with version 7.
You have to go through and get an API TOKEN (Enphase - Envoy V7 local API to CURL-JSON on Windows - #25 by davebuk) and make sure you have the HTTP binding installed.
system
(system)
Closed
45
