Hello, tobias
I have the script. But i dont know where I have to enter my user and password. I do not have a FritzBox.
Hi @Sebastian_Kastner what’s you environment you are running OH.
If it’s a RPi or Lunix you could run the script with your Telekom credentials. User Id (xxx@t-online.de) is parameter 1 and t-online password is parameter 2 on the command line.
getEntertainTVUserID.sh <user@t-online.de> <password>
On other platforms you need to run tcpdump and extract the user id from the packet dump.
There is no event fromthe MR when you power it on and off. So far I didn’t found a way to detect the online/suspend status of the MR.
Hi Markus,
the MR400 have the Error in the post on top.
The same Errors with Binding V2.4-Snapshot.
Go to the thing config and expand [Show properties] and copy here.
i have remove the Thing MR400 and have reboot the OpenHAB server.
Now i have adding the Thing again, the binding not found the MR type automatically:
I can`t select Receiver Model MR400, when i selected paper UI say “Error” without error message.
The Model type ist not save.
in the log file, there are no errors:
EntertainTV: Pairing complete for ‘Telekom Schlafzimmer’
and i can adding items, but i can`t control the MR400 and i become no informations to the items “Progam”, “Description” and the other items.
by the way, i have an MR201 available soon, probably on Sunday evening, for further tests.
first we need to find out the status of rhe initialization. Go to the binding properties, but close the edit mode by clicking on the check mark. There should be a button [Show Properties]
In addition you could set the debugging mode to TRACE (log:set TRAC org.openhab.binding.entertaintv in the OH console)
Status: ONLINE
HIDE PROPERTIES
manFilter | HUAWEI |
serialNumber | |
modelId | dmr_tpb |
ipAddress | 192.168.9.147 |
terminalID | 26A5F0FD7A02C93E07CFC428C499D182 |
userId | 9315609461EBXXXXXXXXXXXXXX99 |
verificationCode | F5600B299780840622C3B2C7FE83DA03 |
localMAC | B8:27:EB:AD:1D:22 |
macAddress | AC:6F:BB:2F:1E:C4 |
wakeOnLAN | 0 |
port | 49152 |
vendor | Deutsche Telekom(Huawei Technologies Co.,Ltd) |
descriptionUrl | /description.xml |
modelFilter | manFilter |
localIP | 192.168.9.20 |
hardwareVersion | 1.1 |
pairingCode | 8EAD18BC |
udn | BB5E21CE-2222-11B2-F918-AC6FBB2F1EC4 |
friendlyName | Telekom Schlafzimmer |
I activated
it looks like pairing was completed successful
what’s about the TRACE log?
what do I have to do to see the trace?
after I activated it?
in the /var/log/openhab2/openhab.log and events.log is nothing.
go to the OH console and enter the command above. output is written to openhab.log
Logger │ Level
org.openhab.binding.entertaintv │ TRACE
i make item “channel up” to ON, log:
2018-10-19 20:54:50.143 [ome.event.ItemCommandEvent] - Item ‘TelekomSchlafzimmer_ChannelUp’ received command ON
2018-10-19 20:54:50.156 [vent.ItemStateChangedEvent] - TelekomSchlafzimmer_ChannelUp changed from OFF to ON
there is no trace output
Maybe it will help you
The xml from the MR401B description URL in the Thing (/xml/xctc.xml):
This XML file does not appear to have any style information associated with it. The document tree is shown below.
<root xmlns="urn:schemas-upnp-org:device-1-0">
<specVersion>
<major>1</major>
<minor>0</minor>
</specVersion>
<device>
<UDN>uuid:c1026e4c-e7fd-5393-a2f3-AC6FBB5C6A01</UDN>
<friendlyName>Telekom Wohnzimmer</friendlyName>
<deviceType>urn:schemas-upnp-org:device:MediaRenderer:1</deviceType>
<manufacturer>Huawei Technologies Co.,Ltd</manufacturer>
<modelName>MR401B</modelName>
<modelNumber>R01A3</modelNumber>
<productVersionNumber>" 391 "</productVersionNumber>
<productType>stb</productType>
<serialNumber/>
<X_wakeOnLan>0</X_wakeOnLan>
<dlna:X_DLNADOC xmlns:dlna="urn:schemas-dlna-org:device-1-0">DMR-1.50</dlna:X_DLNADOC>
<dlna:X_DLNACAP xmlns:dlna="urn:schemas-dlna-org:device-1-0"/>
<serviceList>
<service>
<serviceType>urn:schemas-upnp-org:service:ConnectionManager:1</serviceType>
<serviceId>urn:upnp-org:serviceId:ConnectionManager</serviceId>
<controlURL>/upnp/service/ConnectionManager/Control</controlURL>
<eventSubURL>/upnp/service/ConnectionManager/Event</eventSubURL>
<SCPDURL>/upnp/service/des/cms.xml</SCPDURL>
</service>
<service>
<serviceType>urn:schemas-upnp-org:service:AVTransport:1</serviceType>
<serviceId>urn:upnp-org:serviceId:AVTransport</serviceId>
<controlURL>/upnp/service/AVTransport/Control</controlURL>
<eventSubURL>/upnp/service/AVTransport/Event</eventSubURL>
<SCPDURL>/upnp/service/des/avt.xml</SCPDURL>
</service>
<service>
<serviceType>urn:schemas-upnp-org:service:RenderingControl:1</serviceType>
<serviceId>urn:upnp-org:serviceId:RenderingControl</serviceId>
<controlURL>/upnp/service/RenderingControl/Control</controlURL>
<eventSubURL>/upnp/service/RenderingControl/Event</eventSubURL>
<SCPDURL>/upnp/service/des/rcs.xml</SCPDURL>
</service>
<service>
<serviceType>urn:schemas-upnp-org:service:X-CTC_RemotePairing:1</serviceType>
<serviceId>urn:upnp-org:serviceId:X-CTC_RemotePairing</serviceId>
<controlURL>/upnp/service/X-CTC_RemotePairing/Control</controlURL>
<eventSubURL>/upnp/service/X-CTC_RemotePairing/Event</eventSubURL>
<SCPDURL>/upnp/service/des/X-CTC_RemotePairing.xml</SCPDURL>
</service>
<service>
<serviceType>urn:schemas-upnp-org:service:X-CTC_RemoteControl:1</serviceType>
<serviceId>urn:upnp-org:serviceId:X-CTC_RemoteControl</serviceId>
<controlURL>/upnp/service/X-CTC_RemoteControl/Control</controlURL>
<eventSubURL>/upnp/service/X-CTC_RemoteControl/Event</eventSubURL>
<SCPDURL>/upnp/service/des/X-CTC_RemoteControl.xml</SCPDURL>
</service>
</serviceList>
</device>
</root>
And this is xml from the MR400 description URL in the Thing (/description.xml):
<root xmlns="urn:schemas-upnp-org:device-1-0" xmlns:dlna="urn:schemas-dlna-org:device-1-0">
<specVersion>
<major>1</major>
<minor>0</minor>
</specVersion>
<device>
<UDN>uuid:bb5e21ce-1111-11b2-f918-AC6FBB2F1EC4</UDN>
<friendlyName>Telekom Schlafzimmer</friendlyName>
<manufacturerURL>http://www.huawei.com</manufacturerURL>
<modelName>dmr_tpb</modelName>
<modelNumber>1.1</modelNumber>
<productVersionNumber>100</productVersionNumber>
<modelURL>http://www.huawei.com</modelURL>
<serialNumber/>
<serviceList>
<service>
</service>
<service>
</service>
<service>
</service>
<service>
</service>
<service>
</service>
</serviceList>
</device>
</root>
we need the trace log
go to the openhab console and enter
log:set TRACE org.openhab.binding.entertaintv
reatart OH, wait until initialization is completed
press a button
the output is written to openhab.log as usual
i have a error on the MR401, after the Binding running more than ~30 minutes:
2018-10-21 12:34:14.845 [ome.event.ItemCommandEvent] - Item 'TelekomWohnzimmer_ChannelUp' received command ON
2018-10-21 12:34:14.851 [INFO ] [ertaintv.internal.EntertainTVControl] - EntertainTVControl: Send Key 'CHUP' (keyCode='0x0101')
2018-10-21 12:34:14.855 [DEBUG] [ertaintv.internal.EntertainTVControl] - EntertainTV: sendKey keyCode='0x0101', terminalid='26A5F0FD7A02C93E07CFC428C499D182', pairingCode='8EAD18BC', verificationCode='F5600B299780840622C3B2C7FE83DA03', userId=9315XXXXXXXXXXXXXF99'
2018-10-21 12:34:14.861 [vent.ItemStateChangedEvent] - TelekomWohnzimmer_ChannelUp changed from OFF to ON
2018-10-21 12:34:14.864 [TRACE] [ertaintv.internal.EntertainTVNetwork] - EntertainTVNetwork: POST 'http://192.168.9.147:49152/upnp/service/X-CTC_RemoteControl/Control' - SoapAction='<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:X_CTC_RemoteKey xmlns:u="urn:schemas-upnp-org:service:X-CTC_RemoteControl:1"><InstanceID>0</InstanceID><KeyCode>keyCode=0x0101^26A5F0FD7A02C93E07CFC428C499D182:F5600B299780840622C3B2C7FE83DA03^userID:9315XXXXXXXF99</KeyCode></u:X_CTC_RemoteKey></s:Body></s:Envelope>', Data = '"urn:schemas-upnp-org:service:X-CTC_RemoteControl:1#X_CTC_RemoteKey"'
2018-10-21 12:34:16.871 [ERROR] [.internal.handler.EntertainTVHandler] - EntertainTV: Channel operation failed: Command=ON, value=channelUp, error=java.util.concurrent.TimeoutException
Commands to the MR401 are not working and information from the MR401 is not in openHAB.
After restarting the bundle via console, it will run for ~ 30 minutes,
I think we should fix the connection problems with the MR401 before we proceed with the complete connection problem with the MR400, right?
Here is the Bundle Init Log Trace for MR401 (I can not attach the log as a file to the post, message new users are not allowed to upload attachments. Therefore here directly in the post, unfortunately confusing):
2018-10-21 12:40:34.830 [DEBUG] [org.openhab.binding.entertaintv ] - BundleEvent STOPPING - org.openhab.binding.entertaintv
2018-10-21 12:40:34.845 [DEBUG] [org.openhab.binding.entertaintv ] - ServiceEvent UNREGISTERING - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory, org.openhab.binding.entertaintv.internal.EntertainTVHandlerFactory}={service.id=376, service.bundleid=227, service.scope=bundle, component.name=org.openhab.binding.entertaintv.internal.EntertainTVHandlerFactory, component.id=240} - org.openhab.binding.entertaintv
2018-10-21 12:40:34.878 [hingStatusInfoChangedEvent] - 'entertaintv:receiver:c1026e4c-e7fd-5393-a2f3-AC6FBB5C6A01' changed from ONLINE to UNINITIALIZED
2018-10-21 12:40:34.888 [hingStatusInfoChangedEvent] - 'entertaintv:receiver:c1026e4c-e7fd-5393-a2f3-AC6FBB5C6A01' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2018-10-21 12:40:34.946 [DEBUG] [org.openhab.binding.entertaintv ] - ServiceEvent UNREGISTERING - {javax.servlet.http.HttpServlet}={service.id=377, service.bundleid=227, service.scope=bundle, component.name=org.openhab.binding.entertaintv.internal.EntertainTVNotifyServlet, component.id=241} - org.openhab.binding.entertaintv
2018-10-21 12:40:34.976 [INFO ] [tv.internal.EntertainTVNotifyServlet] - EntertainTV: Servlet stopped
2018-10-21 12:40:34.986 [INFO ] [vice.internal.HttpServiceFactoryImpl] - Unbinding bundle: [org.openhab.binding.entertaintv_2.4.0.201810161802 [227]]
2018-10-21 12:40:34.994 [DEBUG] [org.openhab.binding.entertaintv ] - ServiceEvent UNREGISTERING - {javax.servlet.ServletContext}={osgi.web.version=2.4.0.201810161802, osgi.web.contextpath=/, service.id=378, osgi.web.symbolicname=org.openhab.binding.entertaintv, service.bundleid=227, service.scope=singleton, osgi.web.contextname=default} - org.openhab.binding.entertaintv
2018-10-21 12:40:35.006 [INFO ] [.jetty.server.handler.ContextHandler] - Stopped HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.openhab.binding.entertaintv_2.4.0.201810161802 [227], contextID=default]}
2018-10-21 12:40:35.029 [DEBUG] [org.openhab.binding.entertaintv ] - ServiceEvent UNREGISTERING - {org.eclipse.smarthome.config.discovery.upnp.UpnpDiscoveryParticipant}={service.id=379, service.bundleid=227, service.scope=bundle, component.name=org.openhab.binding.entertaintv.internal.discovery.EntertainTVDiscoveryParticipant, component.id=242} - org.openhab.binding.entertaintv
2018-10-21 12:40:35.107 [DEBUG] [org.openhab.binding.entertaintv ] - BundleEvent STOPPED - org.openhab.binding.entertaintv
2018-10-21 12:40:35.115 [DEBUG] [org.openhab.binding.entertaintv ] - BundleEvent STARTING - org.openhab.binding.entertaintv
2018-10-21 12:40:35.193 [DEBUG] [org.openhab.binding.entertaintv ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory, org.openhab.binding.entertaintv.internal.EntertainTVHandlerFactory}={service.id=380, service.bundleid=227, service.scope=bundle, component.name=org.openhab.binding.entertaintv.internal.EntertainTVHandlerFactory, component.id=243} - org.openhab.binding.entertaintv
2018-10-21 12:40:35.202 [TRACE] [v.internal.EntertainTVHandlerFactory] - EntertainTV.Factory: Activate HandlerFactory
2018-10-21 12:40:35.245 [DEBUG] [org.openhab.binding.entertaintv ] - ServiceEvent REGISTERED - {javax.servlet.http.HttpServlet}={service.id=381, service.bundleid=227, service.scope=bundle, component.name=org.openhab.binding.entertaintv.internal.EntertainTVNotifyServlet, component.id=244} - org.openhab.binding.entertaintv
2018-10-21 12:40:35.253 [INFO ] [vice.internal.HttpServiceFactoryImpl] - Binding bundle: [org.openhab.binding.entertaintv_2.4.0.201810161802 [227]] to http service
2018-10-21 12:40:35.270 [DEBUG] [tv.internal.EntertainTVNotifyServlet] - EntertainTV: HandlerFactory bound to servlet
2018-10-21 12:40:35.293 [INFO ] [rg.ops4j.pax.web.utils.ClassPathUtil] - Ignoring bundle scan for /META-INF/services javax.servlet.ServletContainerInitializer.
2018-10-21 12:40:35.298 [INFO ] [ce.jetty.internal.HttpServiceContext] - registering context DefaultHttpContext [bundle=org.openhab.binding.entertaintv_2.4.0.201810161802 [227], contextID=default], with context-name:
2018-10-21 12:40:35.312 [DEBUG] [org.openhab.binding.entertaintv ] - ServiceEvent REGISTERED - {javax.servlet.ServletContext}={osgi.web.version=2.4.0.201810161802, osgi.web.contextpath=/, service.id=382, osgi.web.symbolicname=org.openhab.binding.entertaintv, service.bundleid=227, service.scope=singleton, osgi.web.contextname=default} - org.openhab.binding.entertaintv
2018-10-21 12:40:35.322 [INFO ] [.jetty.server.handler.ContextHandler] - Started HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.openhab.binding.entertaintv_2.4.0.201810161802 [227], contextID=default]}
2018-10-21 12:40:35.330 [INFO ] [tv.internal.EntertainTVNotifyServlet] - EntertainTV servlet started at '/entertaintv/notify'
2018-10-21 12:40:35.351 [DEBUG] [org.openhab.binding.entertaintv ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.upnp.UpnpDiscoveryParticipant}={service.id=383, service.bundleid=227, service.scope=bundle, component.name=org.openhab.binding.entertaintv.internal.discovery.EntertainTVDiscoveryParticipant, component.id=245} - org.openhab.binding.entertaintv
2018-10-21 12:40:35.357 [DEBUG] [very.EntertainTVDiscoveryParticipant] - EntertainTV: HandlerFactory bound to EntertainTVDiscoveryParticipant
2018-10-21 12:40:35.362 [TRACE] [very.EntertainTVDiscoveryParticipant] - EntertainTV: Activate UpnpDiscovery, configurarion (servicesentertaintv.cfg):
2018-10-21 12:40:35.370 [TRACE] [very.EntertainTVDiscoveryParticipant] - EntertainTV: Device discovered: Huawei Technologies Co.,Ltd - MR401B
2018-10-21 12:40:35.375 [DEBUG] [very.EntertainTVDiscoveryParticipant] - EntertainTV: Discovered an EntertainTV Receiver 'Telekom Wohnzimmer', UDN: 'c1026e4c-e7fd-5393-a2f3-AC6FBB5C6A01', Model MR401B.R01A3
2018-10-21 12:40:35.379 [DEBUG] [very.EntertainTVDiscoveryParticipant] - EntertainTV: Create Thing for device 'Telekom Wohnzimmer' with UDN 'c1026e4c-e7fd-5393-a2f3-AC6FBB5C6A01, Model'MR401B'
2018-10-21 12:40:35.383 [DEBUG] [v.internal.EntertainTVHandlerFactory] - EntertainTV: Discovery results saved for UDN 'C1026E4C-E7FD-5393-A2F3-AC6FBB5C6A01'
2018-10-21 12:40:35.408 [DEBUG] [org.openhab.binding.entertaintv ] - BundleEvent STARTED - org.openhab.binding.entertaintv
2018-10-21 12:40:35.606 [DEBUG] [v.internal.EntertainTVHandlerFactory] - EntertainTV.Factory: Create thing type 'org.eclipse.smarthome.core.thing.internal.ThingImpl@209680fe'
2018-10-21 12:40:35.611 [DEBUG] [.internal.handler.EntertainTVHandler] - DEBUG 1
2018-10-21 12:40:35.614 [DEBUG] [.internal.handler.EntertainTVHandler] - DEBUG 2
2018-10-21 12:40:35.617 [DEBUG] [.internal.handler.EntertainTVHandler] - DEBUG 3
2018-10-21 12:40:35.720 [TRACE] [ertaintv.internal.EntertainTVNetwork] - EntertainTV: initLocalNet(): local OH port = 8080
2018-10-21 12:40:35.725 [DEBUG] [ertaintv.internal.EntertainTVNetwork] - EntertainTV: interface 'eth0': ip='192.168.9.20'
2018-10-21 12:40:35.726 [hingStatusInfoChangedEvent] - 'entertaintv:receiver:c1026e4c-e7fd-5393-a2f3-AC6FBB5C6A01' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2018-10-21 12:40:35.729 [DEBUG] [ertaintv.internal.EntertainTVNetwork] - EntertainTV: site-local address: '192.168.9.20'
2018-10-21 12:40:35.733 [DEBUG] [ertaintv.internal.EntertainTVNetwork] - EntertainTV: skipping interface 'lo'
2018-10-21 12:40:35.738 [DEBUG] [ertaintv.internal.EntertainTVNetwork] - EntertainTV: Local IP address='192.168.9.20', Local MAC address = 'B8:27:EB:AD:1D:22'
2018-10-21 12:40:35.744 [DEBUG] [ertaintv.internal.EntertainTVControl] - EntertainTV: Check device 192.168.9.139:8081
2018-10-21 12:40:35.749 [DEBUG] [ertaintv.internal.EntertainTVNetwork] - EntertainTV: Wake-on-LAN packet sent to 192.168.9.139 / AC:6F:BB:5C:6A:01
2018-10-21 12:40:35.760 [TRACE] [ertaintv.internal.EntertainTVNetwork] - HttpGet: GET http://192.168.9.139:8081/xml/xctc.xml - Response='<?xml version="1.0"?><root xmlns="urn:schemas-upnp-org:device-1-0"><specVersion><major>1</major><minor>0</minor></specVersion><device><UDN>uuid:c1026e4c-e7fd-5393-a2f3-AC6FBB5C6A01</UDN><friendlyName>Telekom Wohnzimmer</friendlyName><deviceType>urn:schemas-upnp-org:device:MediaRenderer:1</deviceType><manufacturer>Huawei Technologies Co.,Ltd</manufacturer><modelName>MR401B</modelName><modelNumber>R01A3</modelNumber><productVersionNumber>" 391 "</productVersionNumber><productType>stb</productType><serialNumber></serialNumber><X_wakeOnLan>0</X_wakeOnLan><dlna:X_DLNADOC xmlns:dlna="urn:schemas-dlna-org:device-1-0">DMR-1.50</dlna:X_DLNADOC><dlna:X_DLNACAP xmlns:dlna="urn:schemas-dlna-org:device-1-0"></dlna:X_DLNACAP><serviceList><service><serviceType>urn:schemas-upnp-org:service:ConnectionManager:1</serviceType><serviceId>urn:upnp-org:serviceId:ConnectionManager</serviceId><controlURL>/upnp/service/ConnectionManager/Control</controlURL><eventSubURL>/upnp/service/ConnectionManager/Event</eventSubURL><SCPDURL>/upnp/service/des/cms.xml</SCPDURL></service><service><serviceType>urn:schemas-upnp-org:service:AVTransport:1</serviceType><serviceId>urn:upnp-org:serviceId:AVTransport</serviceId><controlURL>/upnp/service/AVTransport/Control</controlURL><eventSubURL>/upnp/service/AVTransport/Event</eventSubURL><SCPDURL>/upnp/service/des/avt.xml</SCPDURL></service><service><serviceType>urn:schemas-upnp-org:service:RenderingControl:1</serviceType><serviceId>urn:upnp-org:serviceId:RenderingControl</serviceId><controlURL>/upnp/service/RenderingControl/Control</controlURL><eventSubURL>/upnp/service/RenderingControl/Event</eventSubURL><SCPDURL>/upnp/service/des/rcs.xml</SCPDURL></service><service><serviceType>urn:schemas-upnp-org:service:X-CTC_RemotePairing:1</serviceType><serviceId>urn:upnp-org:serviceId:X-CTC_RemotePairing</serviceId><controlURL>/upnp/service/X-CTC_RemotePairing/Control</controlURL><eventSubURL>/upnp/service/X-CTC_RemotePairing/Event</eventSubURL><SCPDURL>/upnp/service/des/X-CTC_RemotePairing.xml</SCPDURL></service><service><serviceType>urn:schemas-upnp-org:service:X-CTC_RemoteControl:1</serviceType><serviceId>urn:upnp-org:serviceId:X-CTC_RemoteControl</serviceId><controlURL>/upnp/service/X-CTC_RemoteControl/Control</controlURL><eventSubURL>/upnp/service/X-CTC_RemoteControl/Event</eventSubURL><SCPDURL>/upnp/service/des/X-CTC_RemoteControl.xml</SCPDURL></service></serviceList></device></root>'
2018-10-21 12:40:35.763 [DEBUG] [ertaintv.internal.EntertainTVControl] - EntertainTV: Wake-on-LAN is disabled
2018-10-21 12:40:35.766 [DEBUG] [ertaintv.internal.EntertainTVControl] - EntertainTV: Online status verified for device 'Telekom Wohnzimmer' (192.168.9.139:8081, UDN=C1026E4C-E7FD-5393-A2F3-AC6FBB5C6A01)
2018-10-21 12:40:35.771 [DEBUG] [v.internal.EntertainTVHandlerFactory] - EntertainTV: Notification for device registered: udn='C1026E4C-E7FD-5393-A2F3-AC6FBB5C6A01', deviceID='26A5F0FD7A02C93E07CFC428C499D182'
2018-10-21 12:40:35.775 [DEBUG] [ertaintv.internal.EntertainTVControl] - EntertainTV: Subscribe Paring Channel (192.168.9.139:8081)
2018-10-21 12:40:35.779 [DEBUG] [ertaintv.internal.EntertainTVNetwork] - EntertainTVNetwork: Sending data to '192.168.9.139:8081': 'SUBSCRIBE /upnp/service/X-CTC_RemotePairing/Event HTTP/1.1
HOST: 192.168.9.139:8081
CALLBACK: <http://192.168.9.20:8080/entertaintv/notify>
NT: upnp:event
TIMEOUT: Second-300
CONNECTION: close
2018-10-21 12:40:36.284 [DEBUG] [ertaintv.internal.EntertainTVNetwork] - receiver response='HTTP/1.1 200 OK
DATE: Sun, 21 Oct 2018 10:40:35 UTC
Content-Length:0
SID: uuid:8170ed53-0d50-507b-b1f6-f6cde0702c14
TIMEOUT: Second-300
Connection: close
2018-10-21 12:40:36.288 [DEBUG] [ertaintv.internal.EntertainTVControl] - EntertainTV: SUBSCRIBE returned SID '8170ed53-0d50-507b-b1f6-f6cde0702c14'
2018-10-21 12:40:36.292 [DEBUG] [.internal.handler.EntertainTVHandler] - EntertainTV: Thing successfully initialized, pairing...
2018-10-21 12:40:36.295 [INFO ] [ertaintv.internal.EntertainTVControl] - EntertainTVControl: Send Pairing Request (firendlyName='PAD:openHAB', deviceID='26A5F0FD7A02C93E07CFC428C499D182', userID='9315XXXXXXXXXXXXXXXXXXXXXXXXF99')
2018-10-21 12:40:36.299 [TRACE] [ertaintv.internal.EntertainTVNetwork] - EntertainTVNetwork: POST 'http://192.168.9.139:8081/upnp/service/X-CTC_RemotePairing/Control' - SoapAction='<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:X-pairingRequest xmlns:u="urn:schemas-upnp-org:service:X-CTC_RemotePairing:1"><pairingDeviceID>26A5F0FD7A02C93E07CFC428C499D182</pairingDeviceID><friendlyName>PAD:openHAB</friendlyName><userID>9315XXXXXXXXXXXXXXXXXXXXXxF99</userID></u:X-pairingRequest></s:Body></s:Envelope>', Data = '"urn:schemas-upnp-org:service:X-CTC_RemotePairing:1#X-pairingRequest"'
2018-10-21 12:40:36.334 [TRACE] [ertaintv.internal.EntertainTVNetwork] - EntertainTVNetwork: POST 'http://192.168.9.139:8081/upnp/service/X-CTC_RemotePairing/Control' - Response = '<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:X-pairingRequestResponse xmlns:u="urn:schemas-upnp-org:service:X-CTC_RemotePairing:1">
<result>0</result>
</u:X-pairingRequestResponse>
</s:Body> </s:Envelope>'
2018-10-21 12:40:36.337 [DEBUG] [ertaintv.internal.EntertainTVControl] - EntertainTV: Pairing initiated successful.
2018-10-21 12:40:36.336 [TRACE] [tv.internal.EntertainTVNotifyServlet] - EntertainTVServlet: Reqeust from 192.168.9.139:58859/entertaintv/notify (192.168.9.139, HTTP/1.1)
2018-10-21 12:40:36.341 [DEBUG] [tv.internal.EntertainTVNotifyServlet] - EntertainTV.Notify: Pairing code '8EAD18BC' received for deviceID '26A5F0FD7A02C93E07CFC428C499D182'
2018-10-21 12:40:36.346 [hingStatusInfoChangedEvent] - 'entertaintv:receiver:c1026e4c-e7fd-5393-a2f3-AC6FBB5C6A01' changed from INITIALIZING to ONLINE
2018-10-21 12:40:36.350 [DEBUG] [.internal.handler.EntertainTVHandler] - OK, errorMessage=
2018-10-21 12:40:36.354 [DEBUG] [v.internal.EntertainTVHandlerFactory] - EntertainTV.Factory: Create thing type 'org.eclipse.smarthome.core.thing.internal.ThingImpl@cb6c5fec'
2018-10-21 12:40:36.359 [DEBUG] [.internal.handler.EntertainTVHandler] - DEBUG 1
2018-10-21 12:40:36.362 [DEBUG] [.internal.handler.EntertainTVHandler] - DEBUG 2
2018-10-21 12:40:36.365 [DEBUG] [.internal.handler.EntertainTVHandler] - DEBUG 3
2018-10-21 12:40:36.351 [DEBUG] [ertaintv.internal.EntertainTVControl] - verificationCode: Input='8EAD18BC26A5F0FD7A02C93E07CFC428C499D1829315609461EBA31EB238EAEA26860F99', code='F5600B299780840622C3B2C7FE83DA03'
2018-10-21 12:40:36.371 [INFO ] [.internal.handler.EntertainTVHandler] - EntertainTV: Power ON
2018-10-21 12:40:36.375 [INFO ] [.internal.handler.EntertainTVHandler] - EntertainTV: Pairing complete for 'Telekom Wohnzimmer' (UDN 'C1026E4C-E7FD-5393-A2F3-AC6FBB5C6A01', terminalID '26A5F0FD7A02C93E07CFC428C499D182', pairingCode='8EAD18BC', verificationCode='F5600B299780840622C3B2C7FE83DA03', userID='9315XXXXXXXXXXXXXXXXXXXXXXXXXXXXF99')
2018-10-21 12:40:36.389 [TRACE] [ertaintv.internal.EntertainTVNetwork] - EntertainTV: initLocalNet(): local OH port = 8080
I suppose the stb requires a re-pairing ever 30min. I’m already working on a periodic connection check, event re-subscripton and re-pairing.
Hey Guys,
Unfortunately, I always get an error. My user and password are correct. At least I can log in with the user and password in the EntertainApp and website.
What could that be?
Thank you
Hello Sebastian,
i don’t know why the script don’t work at your installation.
You have an Fritzbox and can use Wireshark?
the VOLUP/VOLDOWN probolem is fixed. working on the next build to include health check and recovery
