ENTSO-E Binding: several reasons, no priceing
hi,
  1. java sertificates,… i spend litle time and instaled java from other sources,.. basic ubuntu dose not support version whit correct sertificates
  2. then there was servixe interruptuin,…
  3. and now it says "ERROR:COMM HTTP error 404
Yhis last one is question, where it comes ?
Could there several fuctions more, for example paste copy price inout when it goes doen ???
404 here is probably the binding hitting an entso-e url that moved or a bad area/document id, not your java certs anymore.
if certs were fixed and you got past the handshake, the next failure being 404 usually means the request reached their side and the path/params are wrong. check the binding docs for the current endpoint and your bidding zone code. sometimes their api returns 404 for an empty/invalid document instead of a nicer error.
paste the full thing config (token redacted) and the exact log line if you can.
EntsoE has today made a new migration attempt to the new version and the API calls are temporarely unavailable for stability reasons.
EntsoE informs on this page - https://transparency.entsoe.eu/news
