I’m getting an error when trying to save a sitemap using designer. When I try to modify the sitemap in Habmin it says Error saving…
The problem seems to be - missing EOF at ‘Frame’ ???
Hard to tell without seeing the complete file.
I also suggest to indent the curly brackets (like the 2nd last) as a visual aid for the block structure.
Looking at the image only, there is a opening curly bracket at the end of line Weather_Temperature, where is the closing one?
Thank you
it was a bracket to much…
Good to hear it is working for you
Feel free to close this topic by ticking the tick box, which marks it ‘solved’.
