You can be lead in error by a cache of ephemeris. Try changing the name of your file
Hi @glhopital, thanks for this binding!
Feature request: Add similar switches as in the quote to file
things.
Thanks in advance
Updated:
- Added Switches for event-today and event-tomorrow
Holiday switches are working fine, too.
I plan to add a channel description providing translated strings for raw strings.
BTW, meanwhile the title-today
and next-title
channels are showing the correct translated strings, in my case in German, although I did not change anything, except a couple of server restarts.
I donāt have any files in the ephemeris folders, except one custom dayset xml.
Hi, Iāve just tried to install Ephemeris and Iām facing this error:
[ERROR] [core.thing.internal.ThingManagerImpl] - Exception occurred while calling thing handler factory 'org.openhab.binding.ephemeris.internal.EphemerisHandlerFactory@4d434d2d': Can't find bundle for base name descriptions.holiday_descriptions, locale fr_FR
The only things Iāve performed are:
- install Ephemeris
- import the two things automatically discovered
- none of these two thing work (Status: UNINITIALIZED HANDLER_MISSING_ERROR & )
Am I missing something here?
I think youāre facing a core issue starting Ephemeris. Iāve seen this from time to time. Have you tried restarting OH ?
Youāre right. Not the most elegant way to install and activate a binding, but effective.
There is no Holidays_xx.xml or language properties file needed if you configure this in the MainUI settings for your country. This was surprising for me, too
Well, thatās the thing - I have set my country and province in the MainUI - both in Regional settings and Ephemeris.
