Hmm,
I haven’t had properties-file in my system, placed it now to services folder as well.
Also I changed to default name “holidays_de.xml” and added a new item, did a restart of OH, bt still no success
It looks like information is read somewhere else than from file? As descriptionPropertiesKey is shown up in log, I won’t expect a dependency to country_descriptions_de.properties ?
You can place these XML files anywhere on your file system that openHAB has permission to read. In the calls to the Actions, use the fully qualified path.
As Advent weekends are not included I’m trying to create a custom xml, but these days are not fixed ones.
I already posted this in knx-user-forum (german one) but probably some here also has some tipp or knows where the issue is??
For debugging the XML file you might need to ask over at the Jollyday github project. At this point you are probably among the most experienced with Ephermeris on this forum. I don’t know that many have created custom XML files yet and even fewer have attempted to create relative holiday dates. I know it’s possible though.
You might look at the example xml files on Jollyday for various countries and see if there is something different between your XML and relative dates in the various country XML files.
Just for information, after I read through various xml’s I’ve found something I can use and which solves this issue for me. Thanks for support and hints.
