Ephemeris isWeekend() says undefined
  • Platform information:
    • Hardware: Linux/5.15.84-v7+ (arm)
    • OS: openhabian
    • Java Runtime Environment: 11.0.18
    • openHAB version: 3.4.1
  • Issue of the topic: Ephemeris.isWeekend() is undefined
JSRule:
rules.JSRule({
  triggers: [
    triggers.TimeOfDayTrigger("06:00")
  execute: (event) => {
    let daniel = items.getItem("daniel_Online").state;
    let julia = items.getItem("julia_Online").state;
    console.log('****************=>');
    console.log(!actions.Ephemeris.isWeekend(), !actions.Ephemeris.isBankHoliday(), (daniel == "ON" || julia == "ON"));
    if (
      !actions.Ephemeris.isWeekend() &&
      !actions.Ephemeris.isBankHoliday() &&
      item.sS1.sendCommand("ON");
Output:
2023-02-19 13:52:01.013 [INFO ] [nhab.automation.script.file.rules.js] - ****************=>
2023-02-19 13:52:01.017 [WARN ] [emeris.internal.EphemerisManagerImpl] - This dayset is not configured : weekend
2023-02-19 13:52:01.047 [INFO ] [nhab.automation.script.file.rules.js] - undefined true true
2023-02-19 13:52:01.050 [WARN ] [emeris.internal.EphemerisManagerImpl] - This dayset is not configured : weekend
2023-02-19 13:52:01.065 [ERROR] [nhab.automation.script.file.rules.js] - Failed to execute rule s1OnWeekday-f95970a0-9fa9-484b-9f8f-de4fea01e1e5: ReferenceError: "item" is not defined: ReferenceError: "item" is not defined
at execute (rules.js:261)
at doExecute (/etc/openhab/automation/js/node_modules/openhab/rules/rules.js:242)
2023-02-19 13:52:01.072 [ERROR] [e.automation.internal.RuleEngineImpl] - Failed to execute rule 's1OnWeekday-f95970a0-9fa9-484b-9f8f-de4fea01e1e5': Fail to execute action: 1
Under “Settings” → “Ephemeris” this is set:
Is there any setting I am missing? I’m referring to this doc:
You need to download the localisation support xml file as described and add it to your function call.
In DSL it looks like this:
	Ephemeris.isBankHoliday(new DateTimeType().zonedDateTime.now().plusDays(0),"/etc/openhab/services/Holidays_de.xml" == false)
Do you have an ephemeris.cfg file? If so make sure it defines a weekend dayset. If not this looks like a bug but im not sure where.
Have you installed openhab-js manually? There were some problems with older versions so maybe that’s it.
That’s only required for custom holidays. OP has a problem with isWeekend() which should work with the default config.
Thanks for the information - I don’t have an ephemeris.cfg file as the docu states that you can set them in the UI (which I did) otherwise if no country is selected the system defaults are taken.
I’ll give it a try with the config file this evening and report if it worked.
Cheers,
Daniel
Yes. But I remember problems using ephemeris not working if you do not provide the xml file. I might be wrong though.
The xml file could include “custom” holidays. In fact this is where the regular holidays are stored.
So I tested this and added an ephemeris.cfg file. During startup I can see this in my logs, those settings were set in UI:
2023-02-20 20:43:28.714 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Time zone set to 'Europe/Vienna'.
2023-02-20 20:43:28.847 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Location set to '47.65,12.21'.
2023-02-20 20:43:28.851 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to 'de_DE'.
2023-02-20 20:43:28.854 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Measurement system set to 'SI'.
Under $OH_CONF/services I have a ephemeris.cfg like in the documentation stated. The file contains these lines:
country=de
region=by
dayset-workday=[MONDAY,TUESDAY,WEDNESDAY,THURSDAY,FRIDAY]
dayset-weekend=[SATURDAY,SUNDAY]
Under $OH_CONF/services there is a Holidays_de.xml with the content provided here
So my rule is working now for reasons I can’t get though…
The only thing I’d expect when using actions.Ephemeris.isWeekend() is that it should return a boolean value. Instead I get undefined. Anything I am missing?
could you try
For any reason it is working now … I’m not sure why it didn’t before…
I restarted via service openhab restart (I assume this doesn’t delete any cache). So now I’m having Holiday.xsd, Holidays_de.xml and Ephemeris.cfg under $OH_CONF/services.
For me this sounds like a BUG that setting country and weekend leads to undefined in OH3 JSRules ¯_(ツ)_/¯.
Now I get following output:
2023-02-20 22:00:00.336 [INFO ] [nhab.automation.script.file.rules.js] - ****************=>
2023-02-20 22:00:00.394 [INFO ] [nhab.automation.script.file.rules.js] - christian.GOOD_FRIDAY false false true
From this
console.log(actions.Ephemeris.getNextBankHoliday(), actions.Ephemeris.isWeekend(), actions.Ephemeris.isBankHoliday(), (daniel == "ON" || julia == "ON"));
So now I can turn on my lights more precisely based on workday or holiday. You’ll know:
Happy wife, happy life :slight_smile:
Thanks for your help, it’s very appreciated!
As far as I remember I did the following:
  • openhabian install openhab-js via openhabian-config
  • setting Ephemeris under settings via UI
  • calling actions.Ephemeris.isWeekend() will be undefined.
If you did this some months ago or more you may need to update openhab-js (there’s an option in openhabian-config).
I updated OH to 3.4.1 after release (8th of Jan according to GitHub) and I updated my ressources to the latest version of openhab-js in package.json and installed all dependencies. So they were up to date.
The only thing I haven’t tested so far is, whether or not I set lang, location etc. in system settings (not OH). As the documentation states If no country is provided the service uses your system default locale settings.
