My sensor is a Ultrasonic range meter connected to a ESP8266 it’s checking the water level in a sump pump hole in my basement, I want to get an alarm when there is 10cm remaining before ouching the sensor.
My ESP8266 is using MQTT to send his value to Openhab and since I’m using PubSubClient it is sending a string.
My rule looks like this:
rule "Water level sump"
Item SumpPump changed
if (SumpPump <= 10){
pushover(“Le niveau d’eau de la SumpPump est dangeureusement haut.”)
Everything works but not the pushover alarm (it’s working with others sensors) so it must be the comparison that doesn’t work.
I am trying to do basically the same thing, but with the graphical rule included in oh3. I tried the symbols, but it expects just numerical. I cant choose to do a conditional statement on the same item.
Basically, when the temperature reaches a certain point (which could be read as less than…) then do x.
I tried to set the rule without any particular state, then do a conditional to allow for the less than or equal to, but it won’t allow it.
Sorry to not create a new thread, seemed like this was too close to the same thing…
