Error 401 logging in only via android app
Old thread but this is exactly what happened to me. Cheers
I had the same problem, my phones autocomplete added a space after the email
Worked for me, app must have been stuck on old settings. Thank you!
New install of OpenHAB3 with a 401 using the Android App locally, had to enable/allow Basic Authentication in Settings->System Services->API Security.
From the docs: openhab-docs/configuration/restdocs.md at b8c8ca28fc9f6c01829451b0fc784a11d73ef700 · openhab/openhab-docs · GitHub
YES!!! This was it! Solved my problem.
Many thanks!
Thanks, also helped here. This should be documented better.
I have the error: “Verbindung zum lokalen Server fehlgeschlagen. Sie haben keinen Fernzugriff aktiviert”
