allen
(Allen)
December 28, 2017, 1:25pm
1
Platform information:
Hardware: HP laptop
OS: ubuntu 16
Java Runtime Environment:1.8
openHAB version: v2
Issue of the topic:
Whenever I try to ad things I get the error code in the bottom right corner?
what is it and what can i do about it ?
i am new so i am not always sure about the commands ?
hmerk
(Hans-Jörg Merk)
December 28, 2017, 1:29pm
2
Please be a bit more precise about your java and openHAB version.
MartinKo
(Martin Korsrud)
December 28, 2017, 1:34pm
3
In general this error indicates that there is a conflict between something you´ve added before. Please see
openHAB2 set up on Pi3.
Demo stuff installed.
Thought I would change the weather as the example is Berlin.
I initially changed the WOEID to my location, that didn’t work, tried changing location name, then tried editing the demo.things file.
Obviously none of this worked (there’s no way it would be that easy!)
So thought I would try to put it back the way it was and start again. No that doesn’t work either. It just states “UNINITIALISED” now in grey. If I try to change it, I get: error 409 …
allen
(Allen)
December 28, 2017, 1:41pm
4
basically i selected demo mode when it ran for the first time and i installed the network binding to monitor a device on the network . as i am still learning the system. and nothing works . it picked up things in the inbox but can’t add any thing.
how do a remove openhab and start all over. complete clean openhanded install .
so that i can make selection on first start up and not select the demo mode.
allen
(Allen)
December 28, 2017, 1:44pm
5
java version "1.8.0_151"
Java™ SE Runtime Environment (build 1.8.0_151-b12)
Java HotSpot™ Server VM (build 25.151-b12, mixed mode)
MartinKo
(Martin Korsrud)
December 28, 2017, 1:46pm
6
allen
(Allen)
7
open hab infoVersion: 2.2.0 (Build)
User: openhab (Environment Variable Set)
User Groups: openhab
Directories: Folder Name | Path | User:Group
OPENHAB_HOME | /usr/share/openhab2 | root:root
OPENHAB_RUNTIME | /usr/share/openhab2/runtime | openhab:openhab
OPENHAB_USERDATA | /var/lib/openhab2 | openhab:openhab
OPENHAB_CONF | /etc/openhab2 | allen:allen
OPENHAB_LOGDIR | /var/log/openhab2 | openhab:openhab
allen
(Allen)
December 28, 2017, 2:22pm
8
uninstalled openhab. will do a new install after system update.
MartinKo
(Martin Korsrud)
December 28, 2017, 2:36pm
9
Ups, by the way. If you used a package install, then you should use
https://docs.openhab.org/installation/linux.html#uninstall
to remove
