@chris I got this error when trying to add a new device into the database.
1064 You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near '95,1,1,485)' at line 3
I have seen this, but haven’t managed to track down exactly what command does it. Given that it seems to actually add the device I’ve not been inclined to try and work out what is up (I know - that’s bad, but… ).
