Hej @jaydee73,
I just installed the new openhab 2 RC1 from scratch.
I discovered everthing but when I tried to add my Zipato RGBW lightbulb an error was thrown in the logs.
eventslog:
2017-01-18 20:02:34.547 [hingStatusInfoChangedEvent] - 'zwave:device:e25d115d:node18' changed from UNINITIALIZED to INITIALIZING
2017-01-18 20:02:34.548 [hingStatusInfoChangedEvent] - 'zwave:device:e25d115d:node18' changed from ONLINE to UNINITIALIZED (HANDLER_MISSING_ERROR)
2017-01-18 20:02:34.558 [hingStatusInfoChangedEvent] - 'zwave:device:e25d115d:node18' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2017-01-18 20:02:34.590 [hingStatusInfoChangedEvent] - 'zwave:device:e25d115d:node18' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2017-01-18 20:02:34.591 [hingStatusInfoChangedEvent] - 'zwave:device:e25d115d:node18' changed from UNINITIALIZED (HANDLER_INITIALIZING_ERROR): Could not update configuration, because callback is missing to INITIALIZING
2017-01-18 20:02:34.592 [hingStatusInfoChangedEvent] - 'zwave:device:e25d115d:node18' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2017-01-18 20:02:34.593 [hingStatusInfoChangedEvent] - 'zwave:device:e25d115d:node18' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2017-01-18 20:02:34.593 [ThingUpdatedEvent ] - Thing 'zwave:device:e25d115d:node18' has been updated.
2017-01-18 20:02:34.597 [ThingUpdatedEvent ] - Thing 'zwave:device:e25d115d:node18' has been updated.
2017-01-18 20:02:34.598 [hingStatusInfoChangedEvent] - 'zwave:device:e25d115d:node18' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to UNINITIALIZED (HANDLER_INITIALIZING_ERROR): Could not update configuration, because callback is missing
2017-01-18 20:02:34.598 [ConfigStatusInfoEvent ] - ConfigStatusInfo [configStatusMessages=[]]
And openhab logs:
017-01-18 20:02:34.560 [WARN ] [.core.thing.binding.BaseThingHandler] - Error while applying configuration changes: 'IllegalStateException: Could not update configuration, because callback is missing' - reverting configuration changes on thing 'zwave:device:e25d115d:node18'.
2017-01-18 20:02:34.566 [ERROR] [ome.core.thing.internal.ThingManager] - Exception occured while initializing handler of thing 'zwave:device:e25d115d:node18': java.lang.IllegalStateException: Could not update configuration, because callback is missing
java.util.concurrent.ExecutionException: java.lang.IllegalStateException: Could not update configuration, because callback is missing
at java.util.concurrent.FutureTask.report(Unknown Source)[:1.8.0_111]
at java.util.concurrent.FutureTask.get(Unknown Source)[:1.8.0_111]
at org.eclipse.smarthome.core.common.SafeMethodCaller.callAsynchronous(SafeMethodCaller.java:188)[98:org.eclipse.smarthome.core:0.9.0.b3]
at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:81)[98:org.eclipse.smarthome.core:0.9.0.b3]
at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:65)[98:org.eclipse.smarthome.core:0.9.0.b3]
at org.eclipse.smarthome.core.thing.internal.ThingManager$9.run(ThingManager.java:710)[105:org.eclipse.smarthome.core.thing:0.9.0.b3]
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)[:1.8.0_111]
at java.util.concurrent.FutureTask.run(Unknown Source)[:1.8.0_111]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(Unknown Source)[:1.8.0_111]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)[:1.8.0_111]
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)[:1.8.0_111]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)[:1.8.0_111]
at java.lang.Thread.run(Unknown Source)[:1.8.0_111]
Caused by: java.lang.IllegalStateException: Could not update configuration, because callback is missing
at org.eclipse.smarthome.core.thing.binding.BaseThingHandler.updateConfiguration(BaseThingHandler.java:480)[105:org.eclipse.smarthome.core.thing:0.9.0.b3]
at org.eclipse.smarthome.core.thing.binding.ConfigStatusThingHandler.updateConfiguration(ConfigStatusThingHandler.java:65)[105:org.eclipse.smarthome.core.thing:0.9.0.b3]
at org.openhab.binding.zwave.handler.ZWaveThingHandler.updateNodeProperties(ZWaveThingHandler.java:1401)[209:org.openhab.binding.zwave:2.0.0.RC1]
at org.openhab.binding.zwave.handler.ZWaveThingHandler.bridgeStatusChanged(ZWaveThingHandler.java:454)[209:org.openhab.binding.zwave:2.0.0.RC1]
at org.openhab.binding.zwave.handler.ZWaveThingHandler.initialize(ZWaveThingHandler.java:147)[209:org.openhab.binding.zwave:2.0.0.RC1]
at org.eclipse.smarthome.core.thing.internal.ThingManager$9$1.call(ThingManager.java:713)[105:org.eclipse.smarthome.core.thing:0.9.0.b3]
at org.eclipse.smarthome.core.thing.internal.ThingManager$9$1.call(ThingManager.java:1)[105:org.eclipse.smarthome.core.thing:0.9.0.b3]
at org.eclipse.smarthome.core.common.SafeMethodCaller$CallableWrapper.call(SafeMethodCaller.java:179)[98:org.eclipse.smarthome.core:0.9.0.b3]
... 3 more
2017-01-18 20:02:34.590 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 18: Initialising Thing Node...
Is this normal or should I be worried?
