I have a problem with connect my OpenHAB software with the Z-Wave software:
I have a raspi 3 which installed openhabian. Also I have installed a z-wave hardware.
The z-wave console work very fine. I can switch on/off my single electrical outlet.
Now I want to integrate z-wave in OpenHAB.
So I put in Paper UI -> Configurations -> Things -> Z-Wave Serial Controller in SerialPort /dev/ttyAMA0 .
I have checked the port number in the linux console.
Unfortunately OpenHab get me an error: “Status: OFFLINE - COMMUNICATION_ERROR zwave.thingstate.serial_notfound”
But the same error occured: Status: OFFLINE - COMMUNICATION_ERROR zwave.thingstate.serial_notfound
There are many parameter in the “Configuration Parameters”.in PaperUI
I have set only the “Serial Port” with “/dev/ttyAMA0”, many other parameter are set default (e.g. Network Security Key, Inclusion Mode Timeout)
