I tried with #1234 at Windows 10 and I never had problems before, but now i get these messaged
Launching the openHAB runtime...
__ _____ ____
____ ____ ___ ____ / / / / | / __ )
/ __ \/ __ \/ _ \/ __ \/ /_/ / /| | / __ |
/ /_/ / /_/ / __/ / / / __ / ___ |/ /_/ /
\____/ .___/\___/_/ /_/_/ /_/_/ |_/_____/
/_/ 2.3.0-SNAPSHOT
Build #1234
Hit '<tab>' for a list of available commands
and '[cmd] --help' for help on a specific command.
Hit '<ctrl-d>' or type 'system:shutdown' or 'logout' to shutdown openHAB.
openhab> ~ openhab> java.lang.ClassCastException: org.eclipse.xtext.xbase.impl.XbaseFactoryImpl cannot be cast to org.eclipse.xtext.xbase.XbaseFactory
at org.eclipse.xtext.xbase.impl.XbaseFactoryImpl.init(XbaseFactoryImpl.java:38)
at org.eclipse.xtext.xbase.XbaseFactory.<clinit>(XbaseFactory.java:28)
at org.eclipse.xtext.xbase.impl.XbasePackageImpl.<init>(XbasePackageImpl.java:335)
at org.eclipse.xtext.xbase.impl.XbasePackageImpl.init(XbasePackageImpl.java:362)
at org.eclipse.xtext.xbase.XbasePackage.<clinit>(XbasePackage.java:67)
Do you mean the standard-package at the initial-setup?
Hit ‘’ for a list of available commands
and ‘[cmd] --help’ for help on a specific command.
Hit ‘’ or type ‘system:shutdown’ or ‘logout’ to shutdown openHAB.
C:\openHAB2>start.bat
Launching the openHAB runtime…
WARNING: Running Karaf on a Java HotSpot Client VM because server-mode is not available.
Install Java Developer Kit to fix this.
For more details see http://java.sun.com/products/hotspot/whitepaper.html#client
