Hey,
i am running into some problems to start the openhab, i have installed updated with apt and after reboot the system is not starting.
Could someone please help me to find out why it is not starting?
Regards
Simon
2022-08-12 10:31:10.345 [ERROR] [Events.Framework ] - FrameworkEvent ERROR
org.osgi.framework.BundleException: Could not resolve module: org.openhab.core.auth.jaas [152]
Unresolved requirement: Require-Capability: osgi.ee; filter:="(&(osgi.ee=JavaSE)(version=11))"
Unresolved requirement: Import-Package: org.openhab.core.auth; version="[3.3.0,4.0.0)"
-> Export-Package: org.openhab.core.auth; bundle-symbolic-name="org.openhab.core"; bundle-version="3.3.0"; version="3.3.0"; uses:="org.openhab.core.common.registry"
org.openhab.core [148]
at org.eclipse.osgi.container.Module.start(Module.java:463) ~[org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel$2.run(ModuleContainer.java:1847) ~[org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor$1$1.execute(EquinoxContainerAdaptor.java:136) ~[org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1840) ~[org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1783) ~[org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1745) ~[org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1667) ~[org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) ~[org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:345) [org.eclipse.osgi-3.17.200.jar:?]
2022-08-12 10:31:10.441 [ERROR] [Events.Framework ] - FrameworkEvent ERROR
org.osgi.framework.BundleException: Could not resolve module: org.openhab.core.auth.oauth2client [153]
Unresolved requirement: Import-Package: org.openhab.core.io.net.http; version="[3.3.0,4.0.0)"
-> Export-Package: org.openhab.core.io.net.http; bundle-symbolic-name="org.openhab.core.io.net"; bundle-version="3.3.0"; version="3.3.0"; uses:="javax.net.ssl,org.eclipse.jetty.client,org.eclipse.jetty.http,org.eclipse.jetty.websocket.client,org.openhab.core.library.types"
org.openhab.core.io.net [173]
Unresolved requirement: Import-Package: org.openhab.core.common; version="[3.3.0,4.0.0)"
-> Export-Package: org.openhab.core.common; bundle-symbolic-name="org.openhab.core"; bundle-version="3.3.0"; version="3.3.0"
Unresolved requirement: Import-Package: org.openhab.core.auth.client.oauth2; version="[3.3.0,4.0.0)"
-> Export-Package: org.openhab.core.auth.client.oauth2; bundle-symbolic-name="org.openhab.core"; bundle-version="3.3.0"; version="3.3.0"; uses:="com.google.gson"
Unresolved requirement: Import-Package: org.openhab.core.storage; version="[3.3.0,4.0.0)"
-> Export-Package: org.openhab.core.storage; bundle-symbolic-name="org.openhab.core"; bundle-version="3.3.0"; version="3.3.0"
2022-08-12 10:31:10.595 [ERROR] [Events.Framework ] - FrameworkEvent ERROR
org.osgi.framework.BundleException: Could not resolve module: org.openhab.core.automation [154]
Unresolved requirement: Import-Package: org.openhab.core; version="[3.3.0,4.0.0)"
-> Export-Package: org.openhab.core; bundle-symbolic-name="org.openhab.core"; bundle-version="3.3.0"; version="3.3.0"
2022-08-12 10:31:10.654 [ERROR] [Events.Framework ] - FrameworkEvent ERROR
org.osgi.framework.BundleException: Could not resolve module: org.openhab.core.automation.module.media [155]
Unresolved requirement: Import-Package: org.openhab.core.automation.handler; version="[3.3.0,4.0.0)"
-> Export-Package: org.openhab.core.automation.handler; bundle-symbolic-name="org.openhab.core.automation"; bundle-version="3.3.0"; version="3.3.0"; uses:="org.openhab.core.automation,org.openhab.core.config.core,org.openhab.core.scheduler"
Unresolved requirement: Import-Package: org.openhab.core.audio; version="[3.3.0,4.0.0)"
-> Export-Package: org.openhab.core.audio; bundle-symbolic-name="org.openhab.core.audio"; bundle-version="3.3.0"; version="3.3.0"; uses:="org.openhab.core.library.types"
org.openhab.core.audio [151]
Unresolved requirement: Import-Package: org.openhab.core.automation; version="[3.3.0,4.0.0)"
-> Export-Package: org.openhab.core.automation; bundle-symbolic-name="org.openhab.core.automation"; bundle-version="3.3.0"; version="3.3.0"; uses:="org.openhab.core.automation.dto,org.openhab.core.common.registry,org.openhab.core.config.core,org.openhab.core.storage"
2022-08-12 10:31:10.706 [ERROR] [Events.Framework ] - FrameworkEvent ERROR
org.osgi.framework.BundleException: Could not resolve module: org.openhab.core.automation.module.script [156]
2022-08-12 10:31:10.732 [ERROR] [Events.Framework ] - FrameworkEvent ERROR
