I try to configure a DHT11 Temperature and Humidity Sensor with exec and python.
But i just get a Error
Thing
Thing exec:command:temp [command="bash /home/openhabian/Adafruit_Python_DHT/examples/dht11.sh", interval=60]
dht11.sh:
#!/bin/bash
DHT_DEVICE=11
GPIO_PIN=13
cd /home/openhabian/Adafruit_Python_DHT/examples/
eval `./AdafruitDHT.py $DHT_DEVICE $GPIO_PIN | sed -e 's/*C//g' | sed -e 's/%//$
echo "$Temp"
exit 0
item
String temp_wohnzimmer "Wohnzimmer Temperatur: %s°C" <temperature> {channel="exec:command:temp:output"}
And the Error:
/usr/lib/python2.7/dist-packages/pkg_resources.py:1049:
UserWarning: /var/lib/openhab2/.python-eggs is writable by group/others and
vulnerable to attack when used with get_resource_filename. Consider a more secure
location (set with .set_extraction_path or the PYTHON_EGG_CACHE environment variable).
warnings.warn(msg, UserWarning) Traceback (most recent call last): File "./AdafruitDHT.py",
line 41, in <module> humidity, temperature = Adafruit_DHT.read_retry(sensor, pin)
File "build/bdist.linux-armv7l/egg/Adafruit_DHT/common.py", line 94, in read_retry
File "build/bdist.linux-armv7l/egg/Adafruit_DHT/common.py", line 81, in read
File "build/bdist.linux-armv7l/egg/Adafruit_DHT/Raspberry_Pi_2.py", line 34,
in read RuntimeError: Error accessing GPIO. /usr/lib/python2.7/dist-packages/pkg_resources.py:1049:
more secure location (set with .set_extraction_path or the PYTHON_EGG_CACHE environment variable).
File "./AdafruitDHT.py", line 41, in <module> humidity, temperature = Adafruit_DHT.read_retry(sensor, pin)
I hope you can help me.
Thank you!
