- Platform information:
- Hardware: Qnap NAS armv7
- OS: qnap
- Java Runtime Environment: from openhab docker image
- openHAB version: 3.3.0
- Issue of the topic: please be detailed explaining your issue
- Please post configurations (if applicable):
- Items configuration related to the issue
- Sitemap configuration related to the issue
- Rules code related to the issue
- Services configuration related to the issue
- If logs where generated please post these here using code fences:
My container ran about 3 Weeks then in the night it went down, I tried to restart it and it wont start anymore.
I created also a new container with the same volumes and it fails again.
It looks like the shell does not get the right env vars?
When I start the image and override the entry point with “sh” it is working and “tini” is found…
+ IFS='
++ ls -d /usr/lib/jvm/temurin-11-jdk-armhf
+ export JAVA_HOME=/usr/lib/jvm/temurin-11-jdk-armhf
+ JAVA_HOME=/usr/lib/jvm/temurin-11-jdk-armhf
+ '[' limited = unlimited ']'
+ /etc/ca-certificates/update.d/adoptium-cacerts
/etc/ssl/certs/adoptium/cacerts successfully populated.
+ capsh --print
+ grep -E Current:.+,cap_net_admin,cap_net_raw,.+
+ rm -f /openhab/runtime/instances/instance.properties
+ rm -f /openhab/userdata/tmp/instances/instance.properties
+ NEW_USER_ID=9001
+ NEW_GROUP_ID=9001
+ echo 'Starting with openhab user id: 9001 and group id: 9001'
+ id -u openhab
+ initialize_volume /openhab/conf /openhab/dist/conf
+ volume=/openhab/conf
+ source=/openhab/dist/conf
++ ls -A /openhab/conf
+ '[' -z 'automation
html
icons
items
persistence
rules
scripts
services
sitemaps
sounds
things
transform' ']'
+ initialize_volume /openhab/userdata /openhab/dist/userdata
+ volume=/openhab/userdata
+ source=/openhab/dist/userdata
++ ls -A /openhab/userdata
+ '[' -z 'backup
cache
config
etc
jsondb
kar
logs
marketplace
persistence
secrets
tmp' ']'
++ cmp /openhab/userdata/etc/version.properties /openhab/dist/userdata/etc/version.properties
+ '[' '!' -z ']'
+ chown -R openhab:openhab /openhab
+ sync
+ '[' -d /etc/cont-init.d ']'
+ sync
+ '[' true == false ']'
+ exec gosu openhab tini -s ./start.sh
error: exec: "tini": executable file not found in $PATH
+ IFS='
+ capsh --print
+ NEW_USER_ID=9001
+ NEW_GROUP_ID=9001
+ id -u openhab
html
icons
items
persistence
rules
scripts
services
sitemaps
sounds
things
transform' ']'
+ '[' -z 'backup
cache
config
etc
jsondb
kar
logs
marketplace
persistence
secrets
tmp' ']'
+ '[' '!' -z ']'
+ sync
+ sync
I tried this as well with no data at all, a clean setup and still got the same error:
docker run \
--name openhab1 \
--net=host \
--rm \
-v /etc/localtime:/etc/localtime:ro \
-v /etc/timezone:/etc/timezone:ro \
-e CRYPTO_POLICY=unlimited \
openhab/openhab:3.4.0.M4-debian
Every other docker image is working…
