Meanwhile I have moved out from OpenJDK and checked that this did not help. Currently newer build where timeout is disabled is running stable.
hey @Kai I still have the issue on #1143
works flawlessy for a couple days. all of a sudden no items are updated anymore.
any logging that helps here?
this is from this morning (as said its on build #1143)
06:14:04.559 [INFO ] [marthome.event.ItemStateChangedEvent] - XAIR_temp changed from 21.5 to 21.6
06:14:12.300 [WARN ] [org.apache.karaf.services.eventadmin] - EventAdmin: Blacklisting ServiceReference [{org.osgi.service.event.EventHandler, org.eclipse.smarthome.core.events.EventPublisher}={event.topics=smarthome, component.name=org.eclipse.smarthome.core.internal.events.OSGiEventManager, component.id=71, service.id=182, service.bundleid=110, service.scope=bundle} | Bundle(org.eclipse.smarthome.core_0.10.0.b1 [110])] due to timeout!
06:14:12.379 [WARN ] [org.apache.karaf.services.eventadmin] - EventAdmin: Blacklisting ServiceReference [{org.osgi.service.event.EventHandler, org.eclipse.smarthome.core.events.EventPublisher}={event.topics=smarthome, component.name=org.eclipse.smarthome.core.internal.events.OSGiEventManager, component.id=71, service.id=182, service.bundleid=110, service.scope=bundle} | Bundle(org.eclipse.smarthome.core_0.10.0.b1 [110])] due to timeout!
07:30:14.241 [WARN ] [su.litvak.chromecast.api.v2.Channel ] - Error while reading
su.litvak.chromecast.api.v2.ChromeCastException: Remote socket closed
at su.litvak.chromecast.api.v2.Channel.read(Channel.java:413) [231:org.openhab.binding.chromecast:2.2.0.201712161137]
at su.litvak.chromecast.api.v2.Channel.access$200(Channel.java:50) [231:org.openhab.binding.chromecast:2.2.0.201712161137]
at su.litvak.chromecast.api.v2.Channel$ReadThread.run(Channel.java:132) [231:org.openhab.binding.chromecast:2.2.0.201712161137]
07:30:14.251 [WARN ] [su.litvak.chromecast.api.v2.Channel ] - <-- null payload in message
java.lang.InterruptedException
at java.lang.Object.wait(Native Method)
at su.litvak.chromecast.api.v2.Channel$ResultProcessor.get(Channel.java:239)
at su.litvak.chromecast.api.v2.Channel.send(Channel.java:367)
at su.litvak.chromecast.api.v2.Channel.sendStandard(Channel.java:336)
at su.litvak.chromecast.api.v2.Channel.getStatus(Channel.java:451)
at su.litvak.chromecast.api.v2.ChromeCast.getStatus(ChromeCast.java:179)
at org.openhab.binding.chromecast.internal.ChromecastCommander.handleRefresh(ChromecastCommander.java:87)
at org.openhab.binding.chromecast.handler.ChromecastHandler$Coordinator$1.run(ChromecastHandler.java:231)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
07:35:22.812 [WARN ] [ommandclass.ZWaveBatteryCommandClass] - NODE 12: BATTERY LOW!
