Today I only got examples with short time errors.
From privacy Reasons I searched and replaced the Numbers like [MSN NR1] or [REMOTE NR1].
Here a log with the error like yesterday (inclusive rule Entries with INFO)
Because Numbers this Time allways filled, failure is only temporarily, but maybe it helps:
2021-08-24 15:12:02.925 [INFO ] [t.AVM Fritzbox 12 - Calllist refresh] - TRIGGER CallState changed or ActiveCall changed
2021-08-24 15:12:02.926 [INFO ] [pt.AVM Fritzbox 2 - New Inbound Call] - TRIGGER AFB_Call_Status changed to Ringing
2021-08-24 15:12:02.926 [INFO ] [pt.AVM Fritzbox 2 - New Inbound Call] - ...Not UNDEF -> Value: [MSN NR1],[REMOTE NR1]
2021-08-24 15:12:02.927 [INFO ] [pt.AVM Fritzbox 2 - New Inbound Call] - ......Call 1 ist frei -> [MSN NR1],[REMOTE NR1]
2021-08-24 15:12:02.928 [INFO ] [pt.AVM Fritzbox 2 - New Inbound Call] - ......Call 1 Timestamp -> 1629810722
2021-08-24 15:12:02.929 [INFO ] [pt.AVM Fritzbox 2 - New Inbound Call] - ......Suche internen Namen
2021-08-24 15:12:02.930 [INFO ] [VM Fritzbox 9 - Call Lines-Übersicht] - TRIGGER AFB_Call1_Status or Call2_Status changed
2021-08-24 15:12:02.930 [INFO ] [pt.AVM Fritzbox 2 - New Inbound Call] - ...Suche Name zu Rufnummer [REMOTE NR1]
2021-08-24 15:12:02.931 [TRACE] [nternal.phonebook.Tr064PhonebookImpl] - Normalized '[REMOTE NR1]' to '[REMOTE NR1]', matchString is '[SHORT REMOTE NR1]'
2021-08-24 15:12:02.932 [TRACE] [nternal.phonebook.Tr064PhonebookImpl] - Normalized '[REMOTE NR1]' to '[REMOTE NR1]', matchString is '[SHORT REMOTE NR1]'
2021-08-24 15:12:02.932 [INFO ] [pt.AVM Fritzbox 2 - New Inbound Call] - ......found : [REMOTE NR1]
2021-08-24 15:12:02.933 [TRACE] [ng.tr064.internal.soap.SOAPConnector] - Request: <SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" SOAP-ENV:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><SOAP-ENV:Header/><SOAP-ENV:Body><u:GetCallList xmlns:u="urn:dslforum-org:service:X_AVM-DE_OnTel:1"/></SOAP-ENV:Body></SOAP-ENV:Envelope>
2021-08-24 15:12:02.933 [TRACE] [nternal.phonebook.Tr064PhonebookImpl] - Normalized '[REMOTE NR1]' to '[REMOTE NR1]', matchString is '[SHORT REMOTE NR1]'
2021-08-24 15:12:02.934 [TRACE] [nternal.phonebook.Tr064PhonebookImpl] - Normalized '[REMOTE NR1]' to '[REMOTE NR1]', matchString is '[SHORT REMOTE NR1]'
2021-08-24 15:12:02.966 [TRACE] [ng.tr064.internal.soap.SOAPConnector] - Received response: <?xml version="1.0"?>
<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
<s:Body>
<u:GetCallListResponse xmlns:u="urn:dslforum-org:service:X_AVM-DE_OnTel:1">
<NewCallListURL>https://192.168.10.8:49443/calllist.lua?sid=47995b0c99f583bc</NewCallListURL>
</u:GetCallListResponse>
</s:Body>
</s:Envelope>
2021-08-24 15:12:02.967 [TRACE] [ng.tr064.internal.soap.SOAPConnector] - Storing in cache: com.sun.xml.messaging.saaj.soap.ver1_1.Message1_1Impl@71c08e7a
2021-08-24 15:12:02.967 [TRACE] [ng.tr064.internal.soap.SOAPConnector] - Returning from cache: com.sun.xml.messaging.saaj.soap.ver1_1.Message1_1Impl@71c08e7a
2021-08-24 15:12:02.967 [TRACE] [hab.binding.tr064.internal.util.Util] - Refreshing cache for 'https://192.168.10.8:49443/calllist.lua?sid=47995b0c99f583bc&days=2'
2021-08-24 15:12:03.511 [TRACE] [hab.binding.tr064.internal.util.Util] - XML = <?xml version="1.0" encoding="UTF-8"?>
<root>
<!-- days:2 -->
<!-- max:999 -->
<!-- id:nil -->
<!-- timestamp:nil -->
<!-- calls:400 -->
<timestamp>1444989601</timestamp>
<Call><Id>12280</Id><Type>3</Type><Called>[REMOTE NR1]</Called><Caller>Wohnung</Caller><CallerNumber>[MSN NR1]</CallerNumber><Name></Name><Numbertype>sip</Numbertype><Device>DECT Wohnung</Device><Port>0</Port><Date>24.08.21 14:34</Date><Duration>0:01</Duration><Count></Count><Path /></Call>
<Call><Id>12279</Id><Type>3</Type><Called>[REMOTE NR2]</Called><Caller>Wohnung</Caller><CallerNumber>[MSN NR1]</CallerNumber><Name>[Vorname Nachname1]</Name><Numbertype>sip</Numbertype><Device>DECT Wohnung</Device><Port>0</Port><Date>24.08.21 12:36</Date><Duration>0:09</Duration><Count></Count><Path /></Call>
<Call><Id>12278</Id><Type>1</Type><Caller>[REMOTE NR2]</Caller><Called>Wohnung</Called><CalledNumber>[MSN NR1]</CalledNumber><Name>[Vorname Nachname1]</Name><Numbertype>sip</Numbertype><Device>DECT Wohnung</Device><Port>0</Port><Date>24.08.21 10:14</Date><Duration>0:01</Duration><Count></Count><Path /></Call>
<Call><Id>12277</Id><Type>3</Type><Called>[REMOTE NR2]</Called><Caller>Wohnung</Caller><CallerNumber>[MSN NR1]</CallerNumber><Name>[Vorname Nachname1]</Name><Numbertype>sip</Numbertype><Device>DECT Wohnung</Device><Port>0</Port><Date>24.08.21 10:07</Date><Duration>0:06</Duration><Count></Count><Path /></Call>
<Call><Id>12276</Id><Type>1</Type><Caller>[REMOTE NR3]</Caller><Called>Wohnung</Called><CalledNumber>[MSN NR1]</CalledNumber><Name></Name><Numbertype>sip</Numbertype><Device>DECT Wohnung</Device><Port>0</Port><Date>24.08.21 07:18</Date><Duration>0:01</Duration><Count></Count><Path /></Call>
<Call><Id>12275</Id><Type>3</Type><Called>03020212311</Called><Caller>Büro</Caller><CallerNumber>[MSN NR2]</CallerNumber><Name></Name><Numbertype>sip</Numbertype><Device>IP-OG-Büro Büro</Device><Port>21</Port><Date>23.08.21 17:24</Date><Duration>0:09</Duration><Count></Count><Path /></Call>
<Call><Id>12274</Id><Type>1</Type><Caller>069505077400</Caller><Called>Büro</Called><CalledNumber>[MSN NR2]</CalledNumber><Name></Name><Numbertype>sip</Numbertype><Device>IP-OG-Büro Büro</Device><Port>21</Port><Date>23.08.21 16:01</Date><Duration>0:58</Duration><Count></Count><Path /></Call>
<Call><Id>12273</Id><Type>1</Type><Caller>[REMOTE NR1]</Caller><Called>Wohnung</Called><CalledNumber>[MSN NR1]</CalledNumber><Name></Name><Numbertype>sip</Numbertype><Device>DECT Wohnung</Device><Port>0</Port><Date>23.08.21 12:53</Date><Duration>0:01</Duration><Count></Count><Path /></Call>
<Call><Id>12272</Id><Type>3</Type><Called>06925499395</Called><Caller>Büro</Caller><CallerNumber>[MSN NR2]</CallerNumber><Name></Name><Numbertype>sip</Numbertype><Device>IP-OG-Büro Büro</Device><Port>21</Port><Date>23.08.21 08:58</Date><Duration>0:22</Duration><Count></Count><Path /></Call>
<!-- calls:0 -->
</root>
2021-08-24 15:12:03.514 [TRACE] [hab.binding.tr064.internal.util.Util] - Storing in cache org.openhab.binding.tr064.internal.dto.additions.Root@2f4c72d1
2021-08-24 15:12:03.514 [TRACE] [hab.binding.tr064.internal.util.Util] - Returning from cache: org.openhab.binding.tr064.internal.dto.additions.Root@2f4c72d1
2021-08-24 15:12:03.934 [INFO ] [t.AVM Fritzbox 2 - New Inbound Call1] - ...send Telegram Message
2021-08-24 15:12:08.640 [INFO ] [he_Licht.rules - Küchenlicht Auto an] - Bewegung gemeldet, Prüfe auf AutoModus
2021-08-24 15:12:08.640 [INFO ] [he_Licht.rules - Küchenzeile Auto an] - Bewegung gemeldet, Prüfe AutoModus, ob einschalten
2021-08-24 15:12:08.640 [INFO ] [e_Licht.rules - Küchenzeile Auto aus] - Küchenzeile bleibt trotz Bewegung aus
2021-08-24 15:12:10.351 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'upnpcontrol:upnpserver:4D454930-0000-1000-8001-A813747470D2' to inbox.
2021-08-24 15:12:11.296 [INFO ] [l.script.API EG_Flur_Sensor_Bewegung] - API sent: ON
2021-08-24 15:12:15.929 [INFO ] [t.AVM Fritzbox 12 - Calllist refresh] - TRIGGER CallState changed or ActiveCall changed
2021-08-24 15:12:15.929 [INFO ] [ritzbox 4 - Inbound Call jetzt aktiv] - TRIGGER AFB_Active_Call changed (muss != UNDEF)
2021-08-24 15:12:15.930 [INFO ] [ritzbox 4 - Inbound Call jetzt aktiv] - ...Suche nun richtigen Anruf Call 1 oder 2
2021-08-24 15:12:15.930 [INFO ] [ritzbox 4 - Inbound Call jetzt aktiv] - ...(Extrahiere IDs Call 1)
2021-08-24 15:12:15.931 [INFO ] [ritzbox 4 - Inbound Call jetzt aktiv] - ...Entferne Kommata von Active Call ID
2021-08-24 15:12:15.932 [INFO ] [ritzbox 4 - Inbound Call jetzt aktiv] - ...Es ist Call 1
2021-08-24 15:12:15.933 [TRACE] [ng.tr064.internal.soap.SOAPConnector] - Request: <SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" SOAP-ENV:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><SOAP-ENV:Header/><SOAP-ENV:Body><u:GetCallList xmlns:u="urn:dslforum-org:service:X_AVM-DE_OnTel:1"/></SOAP-ENV:Body></SOAP-ENV:Envelope>
2021-08-24 15:12:15.933 [INFO ] [VM Fritzbox 9 - Call Lines-Übersicht] - TRIGGER AFB_Call1_Status or Call2_Status changed
2021-08-24 15:12:15.958 [TRACE] [ng.tr064.internal.soap.SOAPConnector] - Received response: <?xml version="1.0"?>
<s:Body>
</s:Body>
</s:Envelope>
2021-08-24 15:12:15.959 [TRACE] [ng.tr064.internal.soap.SOAPConnector] - Storing in cache: com.sun.xml.messaging.saaj.soap.ver1_1.Message1_1Impl@6f18b091
2021-08-24 15:12:15.959 [TRACE] [ng.tr064.internal.soap.SOAPConnector] - Returning from cache: com.sun.xml.messaging.saaj.soap.ver1_1.Message1_1Impl@6f18b091
2021-08-24 15:12:15.960 [TRACE] [hab.binding.tr064.internal.util.Util] - Refreshing cache for 'https://192.168.10.8:49443/calllist.lua?sid=47995b0c99f583bc&days=2'
2021-08-24 15:12:16.390 [TRACE] [hab.binding.tr064.internal.util.Util] - XML = <?xml version="1.0" encoding="UTF-8"?>
<root>
<!-- days:2 -->
<!-- max:999 -->
<!-- id:nil -->
<!-- calls:399 -->
<Call><Id>12275</Id><Type>3</Type><Called>[REMOTE NR4]</Called><Caller>Büro</Caller><CallerNumber>[MSN NR2]</CallerNumber><Name></Name><Numbertype>sip</Numbertype><Device>IP-OG-Büro Büro</Device><Port>21</Port><Date>23.08.21 17:24</Date><Duration>0:09</Duration><Count></Count><Path /></Call>
<Call><Id>12274</Id><Type>1</Type><Caller>[REMOTE NR5]</Caller><Called>Büro</Called><CalledNumber>[MSN NR2]</CalledNumber><Name></Name><Numbertype>sip</Numbertype><Device>IP-OG-Büro Büro</Device><Port>21</Port><Date>23.08.21 16:01</Date><Duration>0:58</Duration><Count></Count><Path /></Call>
<Call><Id>12272</Id><Type>3</Type><Called>[REMOTE NR6]</Called><Caller>Büro</Caller><CallerNumber>[MSN NR2]</CallerNumber><Name></Name><Numbertype>sip</Numbertype><Device>IP-OG-Büro Büro</Device><Port>21</Port><Date>23.08.21 08:58</Date><Duration>0:22</Duration><Count></Count><Path /></Call>
<!-- calls:1 -->
<Call><Id>12281</Id><Type>9</Type><Caller>[REMOTE NR1]</Caller><Called>Wohnung</Called><CalledNumber>[MSN NR1]</CalledNumber><Name></Name><Numbertype>sip</Numbertype><Device>DECT Wohnung</Device><Port>0</Port><Date>24.08.21 15:12</Date><Duration>0:01</Duration><Count></Count><Path /></Call>
</root>
2021-08-24 15:12:16.393 [TRACE] [hab.binding.tr064.internal.util.Util] - Storing in cache org.openhab.binding.tr064.internal.dto.additions.Root@607f01c9
2021-08-24 15:12:16.393 [TRACE] [hab.binding.tr064.internal.util.Util] - Returning from cache: org.openhab.binding.tr064.internal.dto.additions.Root@607f01c9
2021-08-24 15:12:16.395 [INFO ] [l.script.AVM Fritzbox 1 - Anrufliste] - TRIGGER - New CallList
2021-08-24 15:12:16.396 [INFO ] [l.script.AVM Fritzbox 1 - Anrufliste] - ...LastCall: Letzter begonnener Anruf der beendet wurde
2021-08-24 15:12:16.398 [INFO ] [l.script.AVM Fritzbox 1 - Anrufliste] - ...Suche Name zu Rufnummer (8) |[REMOTE NR1]|
2021-08-24 15:12:16.399 [TRACE] [nternal.phonebook.Tr064PhonebookImpl] - Normalized '[REMOTE NR1]' to '[REMOTE NR1]', matchString is '[SHORT REMOTE NR1]'
2021-08-24 15:12:16.400 [INFO ] [l.script.AVM Fritzbox 1 - Anrufliste] - ......found : [REMOTE NR1]
2021-08-24 15:12:16.400 [TRACE] [nternal.phonebook.Tr064PhonebookImpl] - Normalized '[REMOTE NR1]' to '[REMOTE NR1]', matchString is '[SHORT REMOTE NR1]'
2021-08-24 15:12:16.401 [TRACE] [nternal.phonebook.Tr064PhonebookImpl] - Normalized '[REMOTE NR1]' to '[REMOTE NR1]', matchString is '[SHORT REMOTE NR1]'
2021-08-24 15:12:16.402 [INFO ] [l.script.AVM Fritzbox 1 - Anrufliste] - ...LastFinishedCall: zuletzt beendeter Anruf
2021-08-24 15:12:16.402 [INFO ] [l.script.AVM Fritzbox 1 - Anrufliste] - ...... Check Index: 0
2021-08-24 15:12:16.415 [INFO ] [l.script.AVM Fritzbox 1 - Anrufliste] - ...... Check Index: 1
2021-08-24 15:12:16.425 [INFO ] [l.script.AVM Fritzbox 1 - Anrufliste] - ...... Check Index: 2
2021-08-24 15:12:16.436 [INFO ] [l.script.AVM Fritzbox 1 - Anrufliste] - ...... Check Index: 3
2021-08-24 15:12:16.446 [INFO ] [l.script.AVM Fritzbox 1 - Anrufliste] - ...... Check Index: 4
2021-08-24 15:12:16.456 [INFO ] [l.script.AVM Fritzbox 1 - Anrufliste] - ...... Check Index: 5
2021-08-24 15:12:16.467 [INFO ] [l.script.AVM Fritzbox 1 - Anrufliste] - ...... Check Index: 6
2021-08-24 15:12:16.477 [INFO ] [l.script.AVM Fritzbox 1 - Anrufliste] - ...... Check Index: 7
2021-08-24 15:12:16.488 [INFO ] [l.script.AVM Fritzbox 1 - Anrufliste] - ...... Check Index: 8
2021-08-24 15:12:16.498 [INFO ] [l.script.AVM Fritzbox 1 - Anrufliste] - ...... Check Index: 9
2021-08-24 15:12:16.508 [INFO ] [l.script.AVM Fritzbox 1 - Anrufliste] - ...... Index: 9 changed! Treffer!
2021-08-24 15:12:16.511 [INFO ] [l.script.AVM Fritzbox 1 - Anrufliste] - ...Suche Name zu Rufnummer (8) |[REMOTE NR1]|
2021-08-24 15:12:16.511 [TRACE] [nternal.phonebook.Tr064PhonebookImpl] - Normalized '[REMOTE NR1]' to '[REMOTE NR1]', matchString is '[SHORT REMOTE NR1]'
2021-08-24 15:12:16.512 [INFO ] [l.script.AVM Fritzbox 1 - Anrufliste] - ......found : [REMOTE NR1]
2021-08-24 15:12:16.513 [ERROR] [l.script.AVM Fritzbox 1 - Anrufliste] - JSON TYPE not defined: 9JSON komplett : [{"localNumber":"[MSN NR1]","remoteNumber":"[REMOTE NR1]","date":"2021-08-24T14:34:00+02","type":3,"duration":1},{"localNumber":"[MSN NR1]","remoteNumber":"[REMOTE NR2]","date":"2021-08-24T12:36:00+02","type":3,"duration":9},{"localNumber":"[MSN NR1]","remoteNumber":"[REMOTE NR2]","date":"2021-08-24T10:14:00+02","type":1,"duration":1},{"localNumber":"[MSN NR1]","remoteNumber":"[REMOTE NR2]","date":"2021-08-24T10:07:00+02","type":3,"duration":6},{"localNumber":"[MSN NR1]","remoteNumber":"[REMOTE NR3]","date":"2021-08-24T07:18:00+02","type":1,"duration":1},{"localNumber":"[MSN NR2]","remoteNumber":"[REMOTE NR4]","date":"2021-08-23T17:24:00+02","type":3,"duration":9},{"localNumber":"[MSN NR2]","remoteNumber":"[REMOTE NR5]","date":"2021-08-23T16:01:00+02","type":1,"duration":58},{"localNumber":"[MSN NR1]","remoteNumber":"[REMOTE NR1]","date":"2021-08-23T12:53:00+02","type":1,"duration":1},{"localNumber":"[MSN NR2]","remoteNumber":"[REMOTE NR6]","date":"2021-08-23T08:58:00+02","type":3,"duration":22},{"localNumber":"[MSN NR1]","remoteNumber":"[REMOTE NR1]","date":"2021-08-24T15:12:00+02","type":9,"duration":1}]
I think, still active Calls get new TYPES not interpretable due to the binding (nearly to the end):
<!-- calls:1 -->
</root>
With TYPE 11 I didn’t find an example today, but I think it is the same but with an outbound call.
