I finally have my 2 Fibaro sensors paired to my z-wave stick. I verified they are on Node 4 and 5. Both of them show green dots next to the Node value in HABmin and the correct Value (Fibaro System [ID:2001, Type 801]).
The issue I’m now having is that when I try to add a Name or Location to the sensor, it disappears after a couple of seconds and the log shows Node 4: Error in doSet - no database found.
I searched and found someone with the same issue who excluded and then included each of these devices and waited a couple of hours for HABmin to find the devices again. I followed that advice, but I’m still getting the same error messages trying to save the name and/or location for both sensors.
I would suggest first to update to the last version of the zwave binding (1.9 snapshot). The 1.8.3 version had a broken database so to make sure this isnt the issue, it’s best to use the latest nightly snapshot.
OK, sorry for the REALLY noob question, but how do I install the latest binding. It seems like the guide that I followed to install the binding was from November 2015.
I downloaded the master.zip file from the z-wave binding wiki, but do I just replace the .jar file, or is there an install that I need to run?
The nightly snapshot is available on the cloudbees server. You can download just the new ZWave binding JAR and replace the binding in your addons folder.
