I updated my Fritzbox 7590 to current FritzOS 7.20.
Since the Update I get the following error of Fritzboxtr064 Binding:
2020-07-06 22:06:05.754 [INFO ] [g.fritzboxtr064.internal.CallMonitor] - Connected to FritzBox on 192.168.xxx.xxx:1012
2020-07-06 22:06:07.999 [ERROR] [ing.fritzboxtr064.internal.Tr064Comm] - Failed to receive valid response from httpGet: null
2020-07-06 22:06:08.001 [ERROR] [ing.fritzboxtr064.internal.Tr064Comm] - Releasing connection to FritzBox because of error!
2020-07-06 22:06:08.004 [WARN ] [ing.fritzboxtr064.internal.Tr064Comm] - Failed to read call list info from URL &days=5
I think, the TR064 Interface changed.
Anyone an idea, what I can do?
that’s strange, I reactivated the Item and the error is here again (of course I rebooted the Fritzbox several times).
Could you please share your Item Definition?
Hi, my Problem is also fixed.
What was the issue?
Updated to 7.20 after that the error occured.
The reason was, unblievable, the android APP “BOXTOGO” which has nothing to do with openhab at all.
But…
After the upgrade of the Fritzbox to 7.20 at the next reconnect, the APP deactivates the caller list of the fritzbox. That caused the “missedCallInDays” Item to not work proper and causing the TR064 Binding to crash.
After activating the caller list on the Fritzbox again. it works without an problem
