Dear all
I always get this error
[ERROR] [b.binding.knx.internal.bus.KNXBinding] - Value '0.0' could not be sent to the KNX bus using datapoint 'command DP 4/4/0 Stufe, DPT main 0 id 5.010, low priority' - giving up after second try: 5.010 Unsigned count: wrong value format: 0.0
The related item is.
Number Stufe "Lüfterstufe [MAP(Luefter.map):%s]" <lueftung> {knx="<5.010:4/4/0"}
the knx DPT is a 5.010 (ABB fan coil actor)
Anybody an idea why I get this error (apparently a wrong data format, although, ABB specifies it to be a DPT 5.010)?
Thank in advance
Best regards
Rolf
