Error in logfile after upgrade from 4.3.2 to 4.3.4
After a second restart of OH 4.3.4 the openhab.log file looks very clean. Then I stared cleaning the items file and when saving I got the following error. I saw this also sometimes in older OH versions but because 4.3.4 looks cleaner than the previous version it is time to figure out how I can avoid this type off error. Who can give a tip to troubleshoot this?
2025-04-08 19:40:54.319 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'OH3all.items'
2025-04-08 19:48:58.162 [ERROR] [st.antlr.ContentAssistContextFactory] - java.lang.RuntimeException: java.lang.NullPointerException
java.util.concurrent.ExecutionException: java.lang.RuntimeException: java.lang.NullPointerException
	at java.util.concurrent.FutureTask.report(FutureTask.java:122) ~[?:?]
	at java.util.concurrent.FutureTask.get(FutureTask.java:191) ~[?:?]
	at org.eclipse.xtext.ide.editor.contentassist.antlr.ContentAssistContextFactory.doCreateContexts(ContentAssistContextFactory.java:181) ~[?:?]
	at org.eclipse.xtext.ide.editor.contentassist.antlr.ContentAssistContextFactory.create(ContentAssistContextFactory.java:131) ~[?:?]
	at org.eclipse.xtext.ide.server.contentassist.ContentAssistService.createProposals(ContentAssistService.java:106) ~[?:?]
	at org.eclipse.xtext.ide.server.contentassist.ContentAssistService.createCompletionList(ContentAssistService.java:78) ~[?:?]
	at org.eclipse.xtext.ide.server.LanguageServerImpl.lambda$26(LanguageServerImpl.java:587) ~[?:?]
	at org.eclipse.xtext.ide.server.WorkspaceManager.doRead(WorkspaceManager.java:458) ~[?:?]
	at org.eclipse.xtext.ide.server.LanguageServerImpl.completion(LanguageServerImpl.java:586) ~[?:?]
	at org.eclipse.xtext.ide.server.LanguageServerImpl.lambda$25(LanguageServerImpl.java:572) ~[?:?]
	at org.eclipse.xtext.ide.server.concurrent.ReadRequest.lambda$1(ReadRequest.java:66) ~[?:?]
	at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539) [?:?]
Caused by: java.lang.RuntimeException: java.lang.NullPointerException
	at org.eclipse.xtext.ide.editor.contentassist.antlr.BaseContentAssistParser.getFollowElements(BaseContentAssistParser.java:246) ~[?:?]
	at org.eclipse.xtext.ide.editor.contentassist.antlr.BaseContentAssistParser.getFollowElements(BaseContentAssistParser.java:237) ~[?:?]
	at org.eclipse.xtext.ide.editor.contentassist.antlr.BaseContentAssistParser.getFollowElements(BaseContentAssistParser.java:232) ~[?:?]
	at org.eclipse.xtext.ide.editor.contentassist.antlr.AbstractContentAssistParser.getFollowElements(AbstractContentAssistParser.java:49) ~[?:?]
	at org.eclipse.xtext.ide.editor.contentassist.antlr.AbstractContentAssistParser.getFollowElements(AbstractContentAssistParser.java:1) ~[?:?]
	at org.eclipse.xtext.ide.editor.contentassist.antlr.BaseContentAssistParser.getFollowElements(BaseContentAssistParser.java:264) ~[?:?]
	at org.eclipse.xtext.ide.editor.contentassist.antlr.ContentAssistContextFactory.handleLastCompleteNodeIsAtEndOfDatatypeNode(ContentAssistContextFactory.java:230) ~[?:?]
	at org.eclipse.xtext.ide.editor.contentassist.antlr.ContentAssistContextFactory$2.call(ContentAssistContextFactory.java:161) ~[?:?]
	at org.eclipse.xtext.ide.editor.contentassist.antlr.ContentAssistContextFactory$2.call(ContentAssistContextFactory.java:1) ~[?:?]
	... 4 more
Do I ask a stupid question?
Is there nobody who can help here?
My guess would be a syntax issue in your OH3all.items file.
Maybe try and start with a simple file to confirm and then add back items till you find the issue?
