is there some simple solution on how to send ERRORs in the log as sendNotification or sendEmail to have them proactively sorted out?
my English is very bad, sorry, if not correctly understood you
http://docs.openhab.org/administration/logging.html#create-log-entries-in-rules
Thanks Sergey for the hint.
Unfortunately I’d like to have some Kind of notification sent to me, if there’s an ERROR in the logfile. Presently I can have a look in the logs and search for ERRORs, what I’d like to have is to be informed, if there are any.
now I understand you! but I do not know such an opportunity.
I guess you want all errors to trigger such a notifiction. There is no builtin function for this, but of course you could use a bash script, which tails openhab.log, searching for the word error
and when emerging, set an item through an api call…
I’d create a new logger, like it is described here at the bottom, where you set the loglevel to ERROR. and then I would follow Udo_Hartmanns idea. By doing so you can always send yourself a notification, when the logfile was altered (maybe like this )
that sounds like a plan!
I’ll get back to it, when I’m ready!..
thanks!
