Here is my rule
import org.eclipse.xtext.xbase.lib.Functions
import org.joda.time.DateTime
var Number washmachineStartDetected = 0
var DateTime washmachineFinishedAt = NULL
var DateTime washmachineStartedAt = NULL
val org.eclipse.xtext.xbase.lib.Functions$Function1<DateTime, Boolean> washmachineNotify = [
DateTime washmachineFinishedAt |
var DateTimeType dt = new DateTimeType(washmachineFinishedAt.toString())
var String message = String.format("Стирка закончена в %s", dt.format("%1$tH:%1$tM"))
sendBroadcastNotification(message)
true
rule "WashmachineNotifications"
Time cron "0 0 * * * ?"
if (washmachineSendNotification.state == ON && washmachineFinishedAt != NULL && washmachineFinishedAt.plusMinutes(50).isBefore(now)) {
washmachineNotify.apply(washmachineFinishedAt)
rule "WashmachineOpen"
Item washmachineOpen received update OPEN
washmachineSendNotification.postUpdate(OFF)
rule "WashmachineStatus"
Item washmachineCurrent changed
//Item washmachineCurrent received update
logInfo("washmachineCurrent", washmachineCurrent.toString())
if (washmachineCurrent.state >= 0.25) {
washmachineStartDetected = washmachineStartDetected + 1
//if (washmachineStartDetected == 3) {
if (washmachineStartDetected == 1) {
washmachineStartedAt = new DateTime()
else if (washmachineCurrent.state == 0) {
washmachineStartDetected = 0;
if (washmachineStartedAt != NULL && washmachineFinishedAt == NULL) {
washmachineFinishedAt = new DateTime()
washmachineSendNotification.postUpdate(ON)
and I got this error
10:40:31.949 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'washmachine.rules', using it anyway:
Cannot reference the field 'NULL' before it is defined
What it mean? And how to fix it?
