Continuing the discussion from [SOLVED] VS Code: "Resource is not available":
program ‘namr.exe’ failed to run: access is deniedat line:1 char:69 + … c programming" ; if ($?) { gcc namr.c -o namr } ; if ($?) { .\namr } + ~~~~~~. at line:1 char:69 + … c programming" ; if ($?) { gcc namr.c -o namr } ; if ($?) { .\namr } + ~~~~~~ + categoryinfo : resourceunavailable: ( [], applicationfailedexc eption + fullyqualifiederrorid : nativecommandfailed
anyone know how to solved this error
