It looks to my like something with the sitemap. Can you post it?
Thats it but it works fine for me.
sitemap iPhone label="Home"
Frame label="Home"
Slider item=FibaroDimmer1_DimmerSwitch1
Switch item=zwave_device_3de88f51_node14_alarm_motion
Switch item=Fibaro_Dimmer1
Text item=zwave_device_3de88f51_node14_sensor_temperature
Frame label="Kitchen"
Switch item=DEMOSW
Switch item=demo_motion
Frame label="Master Bedroom"
Switch item=DEMOSW
Frame label="Bathroom"
Switch item=DEMOSW
Frame label="Anex"
Switch item=DEMOSW
You have Switch and Slider widgets in your sitemap with item=FibaroFGD212Dimmer2_DimmerSwitch1
but that Item does not exist in your system.
You have a Switch widget etc.
I just ignore it because the sitemap works perfectly for me I can use the slider to dim the lights and switches work perfectly too. I only have problems with rules I canât get them to work in any way even through the Rule Engine (Experimental).
It does tell us that you do not have an Item named FibaroFGD212Dimmer2_DimmerSwitch1
Thatâs pretty important because that is the same non-existent Item you are trying to command with your rule. EDIT - oh, no it isnât. This one has a â2â.
The next question then, is why do you think you have an Item by that name? Where did you define it, and why didnât it work?
I think thoes are ghost things that appear with other working things. I sometimes get 3 things and only one of them works for one device.
Theyâre Items. Itâs going to make your life simpler if you can see the difference between Items and Things
Items are openHABs internal models of simple âdevicesâ - switch, number, string. Items are used in rules and UI
Things are descriptions of external devices or services.
channels link Items to Things.
ok I dont get it anymore, I had some sitemap.save copies of the main sitemap and when I deleted it it is all ok now but the rule is still not working.
2020-06-17 21:08:32.484 [ome.event.ItemCommandEvent] - Item 'FibaroDimmer1_DimmerSwitch1' received command 100
2020-06-17 21:08:32.569 [nt.ItemStatePredictedEvent] - FibaroDimmer1_DimmerSwitch1 predicted to become 100
2020-06-17 21:08:32.608 [vent.ItemStateChangedEvent] - FibaroDimmer1_DimmerSwitch1 changed from 0 to 100
2020-06-17 21:08:33.969 [ome.event.ItemCommandEvent] - Item 'FibaroDimmer1_DimmerSwitch1' received command 0
2020-06-17 21:08:34.014 [nt.ItemStatePredictedEvent] - FibaroDimmer1_DimmerSwitch1 predicted to become 0
2020-06-17 21:08:34.041 [vent.ItemStateChangedEvent] - FibaroDimmer1_DimmerSwitch1 changed from 100 to 0
2020-06-17 21:08:34.982 [ome.event.ItemCommandEvent] - Item 'Fibaro_Dimmer1' received command ON
2020-06-17 21:08:35.021 [nt.ItemStatePredictedEvent] - Fibaro_Dimmer1 predicted to become ON
2020-06-17 21:08:35.046 [vent.ItemStateChangedEvent] - Fibaro_Dimmer1 changed from OFF to ON
2020-06-17 21:08:35.934 [ome.event.ItemCommandEvent] - Item 'Fibaro_Dimmer1' received command OFF
2020-06-17 21:08:35.981 [nt.ItemStatePredictedEvent] - Fibaro_Dimmer1 predicted to become OFF
2020-06-17 21:08:35.993 [vent.ItemStateChangedEvent] - Fibaro_Dimmer1 changed from ON to OFF
2020-06-17 21:08:37.231 [ome.event.ItemCommandEvent] - Item 'zwave_device_3de88f51_node14_alarm_motion' received command OFF
2020-06-17 21:08:37.273 [nt.ItemStatePredictedEvent] - zwave_device_3de88f51_node14_alarm_motion predicted to become OFF
2020-06-17 21:08:37.299 [vent.ItemStateChangedEvent] - zwave_device_3de88f51_node14_alarm_motion changed from ON to OFF
2020-06-17 21:08:37.930 [ome.event.ItemCommandEvent] - Item 'zwave_device_3de88f51_node14_alarm_motion' received command ON
2020-06-17 21:08:37.970 [nt.ItemStatePredictedEvent] - zwave_device_3de88f51_node14_alarm_motion predicted to become ON
2020-06-17 21:08:37.997 [vent.ItemStateChangedEvent] - zwave_device_3de88f51_node14_alarm_motion changed from OFF to ON
2020-06-17 21:08:39.023 [ome.event.ItemCommandEvent] - Item 'demo_motion' received command ON
2020-06-17 21:08:39.068 [nt.ItemStatePredictedEvent] - demo_motion predicted to become ON
2020-06-17 21:08:39.099 [vent.ItemStateChangedEvent] - demo_motion changed from OFF to ON
2020-06-17 21:08:39.120 [ome.event.ItemCommandEvent] - Item 'FibaroDimmer1_DimmerSwitch1' received command ON
2020-06-17 21:08:39.143 [nt.ItemStatePredictedEvent] - FibaroDimmer1_DimmerSwitch1 predicted to become ON
2020-06-17 21:08:39.155 [vent.ItemStateChangedEvent] - FibaroDimmer1_DimmerSwitch1 changed from 0 to 100
2020-06-17 21:08:39.906 [ome.event.ItemCommandEvent] - Item 'demo_motion' received command OFF
2020-06-17 21:08:39.946 [nt.ItemStatePredictedEvent] - demo_motion predicted to become OFF
2020-06-17 21:08:39.965 [vent.ItemStateChangedEvent] - demo_motion changed from ON to OFF
2020-06-17 21:08:39.983 [ome.event.ItemCommandEvent] - Item 'FibaroDimmer1_DimmerSwitch1' received command OFF
2020-06-17 21:08:40.023 [nt.ItemStatePredictedEvent] - FibaroDimmer1_DimmerSwitch1 predicted to become OFF
2020-06-17 21:08:40.041 [vent.ItemStateChangedEvent] - FibaroDimmer1_DimmerSwitch1 changed from 100 to 0
2020-06-17 21:17:00.008 [vent.ChannelTriggeredEvent] - astro:sun:local:daylight#event triggered END
2020-06-17 21:17:00.013 [vent.ChannelTriggeredEvent] - astro:sun:local:set#event triggered START
2020-06-17 21:22:00.002 [vent.ChannelTriggeredEvent] - astro:sun:local:set#event triggered END
2020-06-17 21:22:00.005 [vent.ChannelTriggeredEvent] - astro:sun:local:civilDusk#event triggered START
2020-06-17 21:36:25.084 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'home.items' has errors, therefore ignoring it: [6,1]: missing EOF at 'witch'
2020-06-17 21:36:25.089 [temChannelLinkRemovedEvent] - Link 'zwave_device_3de88f51_node13_alarm_motion => zwave:device:3de88f51:node13:alarm_motion' has been removed.
2020-06-17 21:36:25.095 [temChannelLinkRemovedEvent] - Link 'zwave_device_3de88f51_node13_sensor_temperature => zwave:device:3de88f51:node13:sensor_temperature' has been removed.
2020-06-17 21:36:25.097 [temChannelLinkRemovedEvent] - Link 'zwave_device_3de88f51_node13_battery_level => zwave:device:3de88f51:node13:battery-level' has been removed.
2020-06-17 21:36:25.099 [temChannelLinkRemovedEvent] - Link 'FibaroDimmer1_DimmerSwitch1 => zwave:device:3de88f51:node11:switch_dimmer1' has been removed.
2020-06-17 21:36:25.103 [temChannelLinkRemovedEvent] - Link 'zwave_device_3de88f51_node14_alarm_motion => zwave:device:3de88f51:node14:alarm_motion' has been removed.
2020-06-17 21:36:25.108 [temChannelLinkRemovedEvent] - Link 'demo_motion => zwave:device:3de88f51:node14:alarm_motion' has been removed.
2020-06-17 21:36:25.115 [temChannelLinkRemovedEvent] - Link 'zwave_device_3de88f51_node14_battery_level => zwave:device:3de88f51:node14:battery-level' has been removed.
2020-06-17 21:36:25.118 [temChannelLinkRemovedEvent] - Link 'Fibaro_Dimmer1 => zwave:device:3de88f51:node11:switch_dimmer1' has been removed.
2020-06-17 21:36:25.147 [temChannelLinkRemovedEvent] - Link 'zwave_device_3de88f51_node14_sensor_temperature => zwave:device:3de88f51:node14:sensor_temperature' has been removed.
2020-06-17 21:36:36.295 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'home.items'
2020-06-17 21:36:36.366 [.ItemChannelLinkAddedEvent] - Link 'demo_motion-zwave:device:3de88f51:node14:alarm_motion' has been added.
2020-06-17 21:36:36.368 [.ItemChannelLinkAddedEvent] - Link 'Fibaro_Dimmer1-zwave:device:3de88f51:node11:switch_dimmer1' has been added.
2020-06-17 21:36:36.371 [.ItemChannelLinkAddedEvent] - Link 'FibaroDimmer1_DimmerSwitch1-zwave:device:3de88f51:node11:switch_dimmer1' has been added.
2020-06-17 21:36:36.375 [.ItemChannelLinkAddedEvent] - Link 'zwave_device_3de88f51_node14_alarm_motion-zwave:device:3de88f51:node14:alarm_motion' has been added.
2020-06-17 21:36:36.379 [.ItemChannelLinkAddedEvent] - Link 'zwave_device_3de88f51_node14_sensor_temperature-zwave:device:3de88f51:node14:sensor_temperature' has been added.
2020-06-17 21:36:36.382 [.ItemChannelLinkAddedEvent] - Link 'zwave_device_3de88f51_node14_battery_level-zwave:device:3de88f51:node14:battery-level' has been added.
2020-06-17 21:36:36.387 [.ItemChannelLinkAddedEvent] - Link 'zwave_device_3de88f51_node13_alarm_motion-zwave:device:3de88f51:node13:alarm_motion' has been added.
2020-06-17 21:36:36.391 [.ItemChannelLinkAddedEvent] - Link 'zwave_device_3de88f51_node13_sensor_temperature-zwave:device:3de88f51:node13:sensor_temperature' has been added.
2020-06-17 21:36:36.396 [.ItemChannelLinkAddedEvent] - Link 'zwave_device_3de88f51_node13_battery_level-zwave:device:3de88f51:node13:battery-level' has been added.
2020-06-17 21:37:58.376 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'iPhone.sitemap' has errors, therefore ignoring it: [1,1]: missing 'sitemap' at 'ssitemap'
[1,10]: mismatched input 'iPhone' expecting '{'
2020-06-17 21:38:06.561 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'iPhone.sitemap'
Can we see the rule, since you last edited it? Have you checked your openhab.log to see if the rules file refreshed okay after editing?
This is the rule.
//motion sensor rules
rule "light on test"
Item demo_motion changed
if (newState == ON) {
FibaroDimmer1_DimmerSwitch1.sendCommand(ON)
} else {
FibaroDimmer1_DimmerSwitch1.sendCommand(OFF)
and thats what appeadred in logs before about the rule
2020-06-17 21:43:34.246 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'home.rules'
however when I closed the SSH this appeared in the logs
2020-06-17 22:17:06.464 [ERROR] [ersey.server.ServerRuntime$Responder] - An I/O error has occurred while writing a response message entity to the container output stream.
org.glassfish.jersey.server.internal.process.MappableException: org.eclipse.jetty.io.EofException
at org.glassfish.jersey.server.internal.MappableExceptionWrapperInterceptor.aroundWriteTo(MappableExceptionWrapperInterceptor.java:92) ~[?:?]
at org.glassfish.jersey.message.internal.WriterInterceptorExecutor.proceed(WriterInterceptorExecutor.java:162) ~[bundleFile:?]
at org.glassfish.jersey.message.internal.MessageBodyFactory.writeTo(MessageBodyFactory.java:1130) ~[bundleFile:?]
at org.glassfish.jersey.server.ServerRuntime$Responder.writeResponse(ServerRuntime.java:711) [bundleFile:?]
at org.glassfish.jersey.server.ServerRuntime$Responder.processResponse(ServerRuntime.java:444) [bundleFile:?]
at org.glassfish.jersey.server.ServerRuntime$Responder.process(ServerRuntime.java:434) [bundleFile:?]
at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:329) [bundleFile:?]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) [bundleFile:?]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) [bundleFile:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:315) [bundleFile:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:297) [bundleFile:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:267) [bundleFile:?]
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) [bundleFile:?]
at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) [bundleFile:?]
at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) [bundleFile:?]
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) [bundleFile:?]
at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) [bundleFile:?]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388) [bundleFile:?]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341) [bundleFile:?]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228) [bundleFile:?]
at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76) [bundleFile:?]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:852) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:544) [bundleFile:9.4.20.v20190813]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [bundleFile:?]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:536) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1581) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1307) [bundleFile:9.4.20.v20190813]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:293) [bundleFile:?]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:482) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1549) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1204) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) [bundleFile:9.4.20.v20190813]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [bundleFile:?]
at org.eclipse.jetty.server.Server.handle(Server.java:494) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:374) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:268) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:117) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:336) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:313) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:171) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:129) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:367) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:782) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:918) [bundleFile:9.4.20.v20190813]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_252]
Caused by: org.eclipse.jetty.io.EofException
at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:283) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.WriteFlusher.flush(WriteFlusher.java:422) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.WriteFlusher.completeWrite(WriteFlusher.java:378) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.ChannelEndPoint$3.run(ChannelEndPoint.java:132) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:336) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:298) ~[bundleFile:9.4.20.v20190813]
... 6 more
Caused by: java.io.IOException: Broken pipe
at sun.nio.ch.FileDispatcherImpl.write0(Native Method) ~[?:1.8.0_252]
at sun.nio.ch.SocketDispatcher.write(SocketDispatcher.java:47) ~[?:1.8.0_252]
at sun.nio.ch.IOUtil.writeFromNativeBuffer(IOUtil.java:93) ~[?:1.8.0_252]
at sun.nio.ch.IOUtil.write(IOUtil.java:65) ~[?:1.8.0_252]
at sun.nio.ch.SocketChannelImpl.write(SocketChannelImpl.java:468) ~[?:1.8.0_252]
at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:261) ~[bundleFile:9.4.20.v20190813]
... 6 more
2020-06-17 22:17:13.062 [ERROR] [ersey.server.ServerRuntime$Responder] - An I/O error has occurred while writing a response message entity to the container output stream.
... 6 more
... 6 more
2020-06-17 22:17:18.367 [ome.event.ItemCommandEvent] - Item 'FibaroDimmer1_DimmerSwitch1' received command 100
2020-06-17 22:17:18.424 [nt.ItemStatePredictedEvent] - FibaroDimmer1_DimmerSwitch1 predicted to become 100
2020-06-17 22:17:18.445 [vent.ItemStateChangedEvent] - FibaroDimmer1_DimmerSwitch1 changed from 0 to 100
2020-06-17 22:17:20.048 [ome.event.ItemCommandEvent] - Item 'FibaroDimmer1_DimmerSwitch1' received command 0
2020-06-17 22:17:20.100 [nt.ItemStatePredictedEvent] - FibaroDimmer1_DimmerSwitch1 predicted to become 0
2020-06-17 22:17:20.149 [vent.ItemStateChangedEvent] - FibaroDimmer1_DimmerSwitch1 changed from 100 to 0
2020-06-17 22:17:20.159 [vent.ItemStateChangedEvent] - Fibaro_Dimmer1 changed from OFF to ON
2020-06-17 22:17:20.164 [vent.ItemStateChangedEvent] - FibaroDimmer1_DimmerSwitch1 changed from 0 to 100
2020-06-17 22:17:21.747 [vent.ItemStateChangedEvent] - Fibaro_Dimmer1 changed from ON to OFF
2020-06-17 22:17:21.751 [vent.ItemStateChangedEvent] - FibaroDimmer1_DimmerSwitch1 changed from 100 to 0
2020-06-17 22:18:41.619 [INFO ] [panel.internal.HABPanelDashboardTile] - Stopped HABPanel
2020-06-17 22:18:42.252 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2020-06-17 23:24:00.004 [vent.ChannelTriggeredEvent] - astro:sun:local:nauticDusk#event triggered END
Okay, from your events.log earlier, here is rule in action.
First your demo_motion
Item has a state change, exactly what is needed to trigger your rule.
A few milliseconds later, your Item FibaroDimmer1_DimmerSwitch1
receives a command ON, which is exactly what weâd expect the rule to issue.
The rule is running, and does everything you asked of it.
If the result of sending a command to FibaroDimmer1_DimmerSwitch1
is not what you expected, then you need to look at any channel and Thing that you linked to that Item.
That can happen with unexpected UI closures, I wouldnât worry about it. Nothing to do with your rule or Item.
So I checked again all the items and rules and made sure they all have the same name like you suggested but they all do same with channels. Do you know anythings else that might be wrong with it, maybe I have not installed something, maybe I need to write some scrypt or add some variables or something or maybe a binding is missing?
However if not then my only idea is to format it and start from the beginning and maybe it might work but I really appriciate your time and help nonetheless, if you think you have any last ideas then please tell me.
Well, what is the problem exactly? Iâll guess that you expected this Item FibaroDimmer1_DimmerSwitch1 to actually control a light or something?
It probably is something small that is wrong, but if we canât see it then we cannot tell you what.
Can we see your Item definition? Can we see the channel and Thing that you think it is linked to? PaperUI screenshots?
FibaroDimmer1_DimmerSwitch1 is a dimmer that you put inside your light switch and it allows you to controll the light from your phone and that works I can control it. However I tried to make a rule that using demo_motion which is a motion senso that is a zwave device, would turn the lights on when you walk into a room and whenever I move my hand in front of the demo_motion then the device indicates that it detected motion with a red LED blinking once but the rule does not turn the FibaroDimmer1_DimmerSwitch1 dimmer on even that the rule like you said is working.
These are the two Things I am trying to connect Fibaro Dimmer1 and NEO Coolcam
This is the item from the Fibaro Dimmer1 with the items linked that I created in SSH
This is the item from the NEO Coolcam with the items linked that I created in SSH
Is that what you are asking for?
Thatâs brilliant, yes.
If we look at the channel for your Dimmer, it shows two Items linked to it.
It should be fine to link a channel to multiple Items, but I think Iâve seen that mess people about before. Maybe it depends on the binding.
In any case, you donât need two Items linked to the same channel.
I would remove the link to Item Fibaro_Dimmer1
, and then remove the Item.
If you created and linked that Item in an xxx.items file, that is where you have to remove them, too.
That should leave you one link to Item FibaroDimmer!_DimmerSwitch1
, which is the one your test rule is commanding. so that should work.
Because youâve been making lots of changes, and some stuff is not so good at making changes in-flight, it would be smart to reboot openHAB after you have made changes, and then see if the rule works.
When youâve got your light turning on and off, then weâll worry at the motion sensor.
I mean the light is working perfectly fine I can dim it and switch it on and off using HABpanel as well as BasicUI and the physical light bulb does turns on and off when I change it there.
The one above is the dimmer and one below is the switch from the linked items because in the BasicUI I wanted to be able to switch and dim the same item.
The logs from the light dimming and switching
2020-06-18 19:05:04.744 [ome.event.ItemCommandEvent] - Item 'FibaroDimmer1_DimmerSwitch1' received command 0
2020-06-18 19:05:04.867 [nt.ItemStatePredictedEvent] - FibaroDimmer1_DimmerSwitch1 predicted to become 0
2020-06-18 19:05:06.104 [ome.event.ItemCommandEvent] - Item 'FibaroDimmer1_DimmerSwitch1' received command 100
2020-06-18 19:05:06.168 [nt.ItemStatePredictedEvent] - FibaroDimmer1_DimmerSwitch1 predicted to become 100
2020-06-18 19:05:06.212 [vent.ItemStateChangedEvent] - FibaroDimmer1_DimmerSwitch1 changed from 0 to 100
2020-06-18 19:05:07.825 [vent.ItemStateChangedEvent] - Fibaro_Dimmer1 changed from OFF to ON
2020-06-18 19:05:07.882 [vent.ItemStateChangedEvent] - zwave_device_3de88f51_node11_config_decimal_param19 changed from NULL to 0
2020-06-18 19:05:07.898 [ome.event.ItemCommandEvent] - Item 'Fibaro_Dimmer1' received command OFF
2020-06-18 19:05:07.937 [nt.ItemStatePredictedEvent] - Fibaro_Dimmer1 predicted to become OFF
2020-06-18 19:05:07.971 [vent.ItemStateChangedEvent] - Fibaro_Dimmer1 changed from ON to OFF
2020-06-18 19:05:09.610 [vent.ItemStateChangedEvent] - FibaroDimmer1_DimmerSwitch1 changed from 100 to 0
2020-06-18 19:05:10.298 [ome.event.ItemCommandEvent] - Item 'Fibaro_Dimmer1' received command ON
2020-06-18 19:05:10.346 [nt.ItemStatePredictedEvent] - Fibaro_Dimmer1 predicted to become ON
2020-06-18 19:05:10.378 [vent.ItemStateChangedEvent] - Fibaro_Dimmer1 changed from OFF to ON
2020-06-18 19:05:11.987 [vent.ItemStateChangedEvent] - FibaroDimmer1_DimmerSwitch1 changed from 0 to 100
2020-06-18 19:05:13.080 [ome.event.ItemCommandEvent] - Item 'Fibaro_Dimmer1' received command OFF
2020-06-18 19:05:13.122 [nt.ItemStatePredictedEvent] - Fibaro_Dimmer1 predicted to become OFF
2020-06-18 19:05:13.149 [vent.ItemStateChangedEvent] - Fibaro_Dimmer1 changed from ON to OFF
2020-06-18 19:05:14.771 [vent.ItemStateChangedEvent] - FibaroDimmer1_DimmerSwitch1 changed from 100 to 0
2020-06-18 19:05:15.947 [ome.event.ItemCommandEvent] - Item 'FibaroDimmer1_DimmerSwitch1' received command 100
2020-06-18 19:05:15.996 [nt.ItemStatePredictedEvent] - FibaroDimmer1_DimmerSwitch1 predicted to become 100
2020-06-18 19:05:16.031 [vent.ItemStateChangedEvent] - FibaroDimmer1_DimmerSwitch1 changed from 0 to 100
2020-06-18 19:05:17.656 [vent.ItemStateChangedEvent] - Fibaro_Dimmer1 changed from OFF to ON
However if you still want me to try removing the switch item Fibaro_Dimmer1 then I surely can.
Why would you want to keep two Items linked to the same channel? What could it do for you, but add confusion?
You donât do that with multiple Items.
An openHAB Dimmer type Item accepts both ON/OFF commands and numeric % commands.
So the same Item can be used in both Switch widgets and Slider widgets.
sitemap
Switch item=FibaroDimmer1_DimmerSwitch1
That is assuming FibaroDimmer1_DimmerSwitch1 is a Dimmer type Item?
Ok that does makes sense I didnt not think about doing it this way, so I did remove it and I have FibaroDimmer1_DimmerSwitch1 in the test rule and I also reastarted the RPI and the lights are working perfectly. What should I do next, should I do the same with the motion sensor, remove demo_motion and just keep the original Motion Alarm?
Have a look in your events.log, see which motion Item is already working, if any.
Use the working one, discard duplicates.
So when I move my hand in front of the motion sensor nothing appears on the log as if it is not working but the red LED in it tells me it detected motion. However since I created a switch item in the sitemaps then I tried turning it on with the switch and this apprears in the logs
Thats the switch
This is the part of the sitemap in the picture
Frame label="Home"
These are the logs that appear when I turn it ON and OFF
2020-06-19 14:58:29.127 [ome.event.ItemCommandEvent] - Item 'zwave_device_3de88f51_node14_alarm_motion' received command ON
2020-06-19 14:58:29.187 [nt.ItemStatePredictedEvent] - zwave_device_3de88f51_node14_alarm_motion predicted to become ON
2020-06-19 14:58:29.226 [vent.ItemStateChangedEvent] - zwave_device_3de88f51_node14_alarm_motion changed from OFF to ON
2020-06-19 14:58:29.252 [ome.event.ItemCommandEvent] - Item 'FibaroDimmer1_DimmerSwitch1' received command ON
2020-06-19 14:58:29.321 [nt.ItemStatePredictedEvent] - FibaroDimmer1_DimmerSwitch1 predicted to become ON
2020-06-19 14:58:29.357 [vent.ItemStateChangedEvent] - FibaroDimmer1_DimmerSwitch1 changed from 0 to 100
2020-06-19 14:58:58.527 [ome.event.ItemCommandEvent] - Item 'zwave_device_3de88f51_node14_alarm_motion' received command OFF
2020-06-19 14:58:58.571 [nt.ItemStatePredictedEvent] - zwave_device_3de88f51_node14_alarm_motion predicted to become OFF
2020-06-19 14:58:58.596 [vent.ItemStateChangedEvent] - zwave_device_3de88f51_node14_alarm_motion changed from ON to OFF
2020-06-19 14:58:58.602 [ome.event.ItemCommandEvent] - Item 'FibaroDimmer1_DimmerSwitch1' received command OFF
2020-06-19 14:58:58.639 [nt.ItemStatePredictedEvent] - FibaroDimmer1_DimmerSwitch1 predicted to become OFF
2020-06-19 14:58:58.651 [vent.ItemStateChangedEvent] - FibaroDimmer1_DimmerSwitch1 changed from 100 to 0
