I have just got OpenHAB installed, and controlling a Radio Frequency node - so I am happy with its current functionality as a concept and look forward to expanding it much further.
I am trying to move to the next step and having the UI on my iPad with myOpenHAB - this is where I seem to have got stuck.
I believe I have done all the myopenhab log in and set up bits correctly online, as I have the confirmation email (which I followed the link and authenticated).
I filled in my username and password on the ipad app, and it wont connect to the server.
looking at tail -f /var/log/openhab/openhab.log I am getting the following error when I try to connect;
[o.u.i.items.ItemUIRegistryImpl] - Cannot find page for id ‘null’.
I was getting another issue (it sounded worse - it thought it was an attack…) before I changed the user.cfg file to include my username=password
As long as you want to connect to your openhab server internally through your network you don’t need my.openhab. Not with a browser and not with any app.
If you want to connect to your openhab server from outside your network, one way is to use my.openhab.
I would suggest to first get everything running without my.openhab.
Unfortunately I’m still getting the same message every time I try to load/refresh the OpenHab app;
2015-10-26 20:07:07.696 [WARN ] [o.u.i.items.ItemUIRegistryImpl] - Cannot find page for id ‘null’.
I have made the changed you recommended, and restarted openHab.
The only other issue I can see in the log file appears to come from the config file itself - could his mean its not loading the config file properly?;
2015-10-26 20:05:46.394 [WARN ] [o.config.core.ConfigDispatcher] - Cannot parse line ‘# This is the default configuration file, which comes with every openHAB distribution.’ of main configuration file ‘/etc/openhab/configurations/openhab.cfg’.
For the moment I don’t need to connect to OpenHab from outside the network, so your solution, should I get it working would be great to go forward with!
Also, for what its worth, it appears the my.OpenHab service is running and is connected to the right UUID. I have cross checked this with my myopenhab log in information also. (I already followed the guide, which is why I posted this thread as I couldn’t get it to work following the simple instructions )
2015-10-26 20:06:24.271 [INFO ] [.myopenhab.internal.MyOHClient] - Connected to my.openHAB service (UUID = 770bdbd7-xxxx-xxxx-xxxx-xxxxxxx57662, base URL = http://localhost:8080)
It is related to this topic (Link) and explains that you cant edit the config file with notepad or wordpad - which I was doing as my working files are on a network location on a raspberry pi, which I don seem to be able to point the designer to.
Unfortunately this hasn’t made anything work
I have found this in the log file which has the word ‘null’ in it. Could this be where my main issue is coming from? Otherwise I cant find the word in any of my files
