my openhab server failed last weekend. After doing the setup again I am receiving an error in my log which was not there before. Settings are the same because it is from backuped docker volume.
Any ideas where it comes from?
2019-07-11 22:14:50.494 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Temperatur Differenz Aussen': An error occurred during the script execution: Couldn't invoke 'assignValueTo' for feature JvmVoid: (eProxyURI: rolladen_steuerung.rules#|::0.2.0.2.0.2.1.0.0.1.0.0::0::/1)
var boolean log = true
var boolean development = false
var Number schliesswertGr = 80
var Number schliesswertKl = 75
var Number aussentempschwelle = 15
rule "Temperatur Differenz Aussen"
Item HeatPump_Temperature_1 received update
or
Item TemperatureAussenVorne received update
or
Time cron "0 */5 * * * ?"
or
Item RolloAutomatik changed
//Item HeatPump_Temperature_1 received update
//or
//Azimuth und Elevation auslesen
var Number AzimuthNow = Azimuth.state
var Number ElevationNow = Elevation.state
if ((ElevationNow <= 0 && ElevationNow >= 80) || RolloAutomatik.state == OFF || HeatPump_Temperature_1.state <= aussentempschwelle || (AzimuthNow < 100 && AzimuthNow > 285) ) {
if (now.getHourOfDay < 8 || now.getHourOfDay > 19) {
sonne = false
return;
AziOGSued.postUpdate(OFF)
AziEGSued.postUpdate(OFF)
AziEGSuedMitte.postUpdate(OFF)
AziWest.postUpdate(OFF)
Sun.postUpdate(OFF)
return;
else {
//Temperaturdifferenz berechnen und senden
var Number TempAussDiff = (TemperatureAussenVorne.state as Number) - (HeatPump_Temperature_1.state as Number)
var Number Diff = (HeatPump_Temperature_1.state as Number) - (TemperatureAussenDifferenz.state as Number)
var Number tau = 10 // Glaettungsfaktor, 1 waere keine Glaettung
TempAussDiff = TempAussDiff + (Diff / 10)
TemperatureAussenDifferenz.postUpdate(TempAussDiff)
var Boolean sonne = Sun.state
if (sonne == ON) sonne = true
else sonne = false
if (TempAussDiff >= 6 && sonne == false || sonne && TempAussDiff > 3 || development ) {
sonne = true
Sun.postUpdate(ON)
if (AzimuthNow > 105 && AzimuthNow < 196) {
if (ElevationNow > 45) AziOGSued.sendCommand(OFF)
else (AziOGSued.sendCommand(ON))
AziEGSued.sendCommand(ON)
AziWest.sendCommand(OFF)
AziEGSuedMitte.sendCommand(ON)
if (AzimuthNow > 196 && AzimuthNow < 260) {
AziWest.sendCommand(ON)
if (AzimuthNow > 260 && AzimuthNow < 285) {
AziEGSued.sendCommand(OFF)
AziEGSuedMitte.sendCommand(OFF)
else if (TempAussDiff <= 3 && sonne) {
createTimer(now.plusMinutes(5), [ | // schlafe 5 minuten
if ((TemperatureAussenVorne.state as Number) - (HeatPump_Temperature_1.state as Number) + (tau * ((HeatPump_Temperature_1.state as Number) - (TemperatureAussenDifferenz.state as Number))) < 3) {
sonne = false
Sun.postUpdate(OFF)
// ON RULES
rule "Rolladen AziOGSued"
Item AziOGSued received command ON
if ( SchlafzimmerRollo_S_OUT.state == 1) SchlafzimmerRollo_S_IN.sendCommand(schliesswertKl)
if ( KindMaxRollo_S_OUT.state == 1) KindMaxRollo_S_IN.sendCommand(schliesswertKl)
if (log) logInfo("****RolloSteuerung****", "AziOGSued Kommandos gesendet")
rule "Rolladen AziWest"
Item AziWest received command ON
if (log) logInfo("****RolloSteuerung****", "AziWest Kommandos gesendet" + KindEmmiRollo_W_OUT.state)
if ( KindEmmiRollo_W_OUT.state == 1) KindEmmiRollo_W_IN.sendCommand(schliesswertGr)
if ( WohnzimmerRollo_W_OUT.state == 1) {
WohnzimmerRollo_W_IN.sendCommand(schliesswertGr)
if ( BueroRollo_W_OUT.state == 1) BueroRollo_W_IN.sendCommand(schliesswertGr)
if (log) logInfo("****RolloSteuerung****", "AziWest Kommandos gesendet")
rule "Rolladen AziEGSued"
Item AziEGSued received command ON
if ( WohnzimmerRollo_SW_OUT.state == 1) WohnzimmerRollo_SW_IN.sendCommand(schliesswertGr)
if ( WohnzimmerRollo_SO_OUT.state == 1) WohnzimmerRollo_SO_IN.sendCommand(schliesswertGr)
if (log) logInfo("****RolloSteuerung****", "AziEGSued Kommandos gesendet")
rule "Rolladen AziEGSuedMitte"
Item AziEGSuedMitte received command ON
var aussperrschutz = WohnzimmerFenster_S.state
if (log) logInfo("****RolloSteuerung****", "Aussperrschutz" + aussperrschutz)
if (aussperrschutz == NULL) aussperrschutz = 'OPEN'
if (aussperrschutz == 'CLOSED' && WohnzimmerRollo_S_OUT.state == 1 ) WohnzimmerRollo_S_IN.sendCommand(schliesswertGr)
else AziEGSuedMitte.postUpdate(OFF)
if (log) logInfo("****RolloSteuerung****", "AziEGSuedMitte Kommandos gesendet")
// OFF RULES
Item AziOGSued received command OFF
SchlafzimmerRollo_S_IN.sendCommand(1)
KindMaxRollo_S_IN.sendCommand(1)
Item AziWest received command OFF
KindEmmiRollo_W_IN.sendCommand(1)
//KindMaxRollo_W_IN.sendCommand(1)
WohnzimmerRollo_W_IN.sendCommand(1)
BueroRollo_W_IN.sendCommand(1)
Item AziEGSued received command OFF
WohnzimmerRollo_SW_IN.sendCommand(1)
WohnzimmerRollo_SO_IN.sendCommand(1)
Item AziEGSuedMitte received command OFF
WohnzimmerRollo_S_IN.sendCommand(1)
