If you ask me, I really don’t know but I have performed an upgrade to 4.1.
How to find out what openhab version is additionally installed ?
I don’t have experience with package management on MacOS.
How did you install Java 17 ?
Does this Installing & switching between multiple JDK on macOS | by Manvendra P Singh | Medium help ?
Installation is performed by double click at the *.dmg file, the installer.
Everything else is performed automatically.
No I tried installation, reinstallation …
openhab is always looking for a jdk11 version
Do you have more than one Java version installed ?
If this is the case is it possble to remove JDK11 ?
If not can you try to force using 17 by setting environment variables like JAVA_HOME that points to version 17 ?
I tried
setjdk 17
but nothing changed
The enviroment variables $xxxx are not in use at macos.
Did you check /etc/profile
for version specific configurations? If I search for your error message it seems to be one of the places which may need to be updated.
at mac
if [ -x /usr/libexec/path_helper ]; then
eval /usr/libexec/path_helper -s
fi
if [ “${BASH-no}” != “no” ]; then
[ -r /etc/bashrc ] && . /etc/bashrc
fi
usr/libexec/java_home -V
Matching Java Virtual Machines (1):
17.0.8.1, x86_64: “Zulu 17.44.53” /Library/Java/JavaVirtualMachines/zulu-17.jdk/Contents/Home
Yes, but at macs the file only a general script.
Instead of
can you try to run
sh -x start.sh
and see if that gives some more information about what is set.
sh -x start.sh
Thank you for that trial. I did expect it to show more.
So we need to check something else. What is shown by executing:
/usr/libexec/java_home -V
Could you further check the following. In directory … you should find a file setenv.
In the download from openhab.org I see this code
locateJava() {
# Setup the Java Virtual Machine
if ${cygwin} ; then
[ -n "${JAVA}" ] && JAVA=$(cygpath --unix "${JAVA}")
[ -n "${JAVA_HOME}" ] && JAVA_HOME=$(cygpath --unix "${JAVA_HOME}")
fi
if [ "x${JAVA_HOME}" = "x" ] && [ "${darwin}" = "true" ]; then
JAVA_HOME="$(/usr/libexec/java_home -v 11)"
fi
if [ "x${JAVA}" = "x" ] && [ -r /etc/gentoo-release ] ; then
JAVA_HOME=$(java-config --jre-home)
fi
if [ "x${JAVA}" = "x" ]; then
if [ "x${JAVA_HOME}" != "x" ]; then
if [ ! -d "${JAVA_HOME}" ]; then
die "JAVA_HOME is not valid: ${JAVA_HOME}"
fi
JAVA="${JAVA_HOME}/bin/java"
else
JAVA=$(command -v java)
die "java command not found"
fi
fi
fi
if [ "x${JAVA_HOME}" = "x" ]; then
JAVA_HOME="$(dirname "$(dirname "$(pathCanonical "${JAVA}")")")"
fi
Pay attention to the row that contains
That row is only executed if JAVA_HOME is not set and it then will set JAVA_HOME to use version 11.
Could you try to set JAVA_HOME to the correct directory to prevent this row from being executed.
17.0.8.1, x86_64: "Zulu 17.44.53" /Library/Java/JavaVirtualMachines/zulu-17.jdk/Contents/Home
I have now removed the jdk17 double installation:
It looks much better but does’t solve the problem
Try on command line
export JAVA_HOME=$(/usr/libexec/java_home -v 17)
then check if JAVA_HOME is set in the current shell:
echo $JAVA_HOME
Does the startup now work ? If it does you need to make sure that the JAVA_HOME variable is set before running start.sh
I have tried to solve the problem this way:
generate in home directory
.zshrc
export JAVA_HOME=(/Library/Java/JavaVirtualMachines/zulu-17.jdk/Contents/Home)
but no effect:
zsh
echo $JAVA_HOME
root@lbpm ~ # /Users/openhab/openhab/./start.sh
Launching the openHAB runtime…
Unable to find any JVMs matching version “11”.
my .zshrc has now additionally the folllowing line
./start.sh
Thank You very much. The error message vanished
which results in
