Hi All
Does anyone know why this has started to occur? The light will not switch off, BackEveSw1 which is a Zwave light. Ive also noticed the zwave map from Habmin has disappeared.
06:27:53.552 [WARN ] [ipse.smarthome.core.items.GenericItem] - failed notifying listener 'gAllDimmers (Type=GroupItem, BaseType=DimmerItem, Members=3, State=100 .00000000, Label=All Dimmers, Category=null, Tags=[Lighting])' about state updat e of item BackEveDim1: Value must be between 0 and 100
java.lang.IllegalArgumentException: Value must be between 0 and 100
at org.eclipse.smarthome.core.library.types.PercentType.validateValue(Pe rcentType.java:58) [94:org.eclipse.smarthome.core:0.10.0.201808242044]
at org.eclipse.smarthome.core.library.types.PercentType.<init>(PercentTy pe.java:53) [94:org.eclipse.smarthome.core:0.10.0.201808242044]
at org.eclipse.smarthome.core.library.types.DecimalType.as(DecimalType.j ava:160) [94:org.eclipse.smarthome.core:0.10.0.201808242044]
at org.eclipse.smarthome.core.internal.items.ItemStateConverterImpl.conv ertToAcceptedState(ItemStateConverterImpl.java:58) [94:org.eclipse.smarthome.cor e:0.10.0.201808242044]
at org.eclipse.smarthome.core.items.GroupItem.stateUpdated(GroupItem.jav a:373) [94:org.eclipse.smarthome.core:0.10.0.201808242044]
at org.eclipse.smarthome.core.items.GenericItem$1.run(GenericItem.java:2 49) [94:org.eclipse.smarthome.core:0.10.0.201808242044]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor. java:1149) [?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor .java:624) [?:?]
I did have this item, which ive removed to see if it stops:
Group:Dimmer:SUM gAllDimmers "All Dimmers" [ "Lighting" ]
