Error Message when rule is triggered
Hy to everyone!
i createt my first rule
rule "Change all Dimmers"
    Item Master_Volume_Slider changed
    var previousValue = Master_Volume_Slider.previousState as Number
    var newValue = Master_Volume_Slider.state as Number
    var Difference = newValue - previousValue
    Master_Volume.forEach( i | i.sendCommand((i.state as Number) + Difference))
when the rule is triggered by sliding the Master Volume slider, i get this error in the Log.
2018-02-17 23:13:36.097 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule ‘Change all Dimmers’: Could not cast org.openhab.core.persistence.internal.QueryablePersistenceServiceDelegate$1@2abd16 to java.lang.Number; line 5, column 25, length 44
Could someone tell me, what this error is meaning?
Is there an error in my code or in my configuration of openhab?
Thanks!
Hi there,
I seem to recognise this rule!
Have you got persistence set up?
You need this to access the previousState property
Regards
Hy!
I have istalled MySQL Persistence and RRD4j Persistence.
MySql i dont use until now.
Change it to Master_Volume_Slider.previousState().state and it should work
There you go…
Told you I wasn’t very good!!
Worst is, I used this before :slight_smile:
Good luck!
