Error on a timertimer
I’m using this rule
			temporizadorDespertar = createTimer(now.plusMinutes(retrasoEncendido)) [|
				//callScript("Lavadora")
                //programacionEncendidoActivado.sendCommand(OFF)
				//logInfo("DESPERTAR", "Hora de despertar")
				if ( (Posicion_Olvi.state as Number).intValue  == 3 ) {
						Temperatura_Programada.sendCommand((Temperatura_Comfort_Olvi_Mod.state as Number ).floatValue)
					else {
						if (((Posicion_Valentin.state as Number).intValue == 3) ) {
							Temperatura_Programada.sendCommand((Temperatura_Comfort_Valentin_Mod.state as Number ).floatValue)
						else {
							if ((Posicion_Olvi.state as Number).intValue  == 2 ) {
								Temperatura_Programada.sendCommand((Temperatura_Cerca_Olvi_Mod.state as Number ).floatValue)
							else {
								if (((Posicion_Valentin.state as Number).intValue == 2)) {
									Temperatura_Programada.sendCommand((Temperatura_Cerca_Valentin_Mod.state as Number ).floatValue)
								else {
									if (((Posicion_Valentin.state as Number).intValue == 0) && (Posicion_Olvi.state as Number).intValue  == 0 ) {
										Temperatura_Programada.sendCommand((Temperatura_Muy_Lejos_Mod.state as Number ).floatValue)
									else {
										Temperatura_Programada.sendCommand((Temperatura_Lejos_Mod.state as Number ).floatValue)
and getting the following error at the time the timer is suposed to run
2019-03-28 22:30:00.258 [ERROR] [org.quartz.core.JobRunShell         ] - Job DEFAULT.2019-03-28T22:30:00.256+01:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
  org.eclipse.xtext.xbase.impl.XIfExpressionImpl@c254d5
} ] threw an unhandled Exception:
	at org.eclipse.smarthome.model.script.engine.ScriptError.<init>(ScriptError.java:66) ~[?:?]
	at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:140) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:902) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:865) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:224) ~[?:?]
	at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:226) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:204) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:768) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:220) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:500) ~[?:?]
	at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter._doEvaluate(ScriptInterpreter.java:243) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:234) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluateArgumentExpressions(XbaseInterpreter.java:1116) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1046) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeFeature(XbaseInterpreter.java:992) ~[?:?]
	at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:151) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:226) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:458) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:244) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:447) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:228) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:190) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.ClosureInvocationHandler.doInvoke(ClosureInvocationHandler.java:46) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.AbstractClosureInvocationHandler.invoke(AbstractClosureInvocationHandler.java:29) ~[?:?]
	at com.sun.proxy.$Proxy182.apply(Unknown Source) ~[?:?]
	at org.eclipse.smarthome.model.script.internal.actions.TimerExecutionJob.execute(TimerExecutionJob.java:49) ~[?:?]
	at org.quartz.core.JobRunShell.run(JobRunShell.java:202) [107:org.eclipse.smarthome.core.scheduler:0.10.0.oh240]
	at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:573) [107:org.eclipse.smarthome.core.scheduler:0.10.0.oh240]
2019-03-28 22:30:00.401 [ERROR] [org.quartz.core.ErrorLogger         ] - Job (DEFAULT.2019-03-28T22:30:00.256+01:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
} ] threw an exception.
org.quartz.SchedulerException: Job threw an unhandled exception.
	at org.quartz.core.JobRunShell.run(JobRunShell.java:213) [107:org.eclipse.smarthome.core.scheduler:0.10.0.oh240]
Caused by: java.lang.NullPointerException
	at org.quartz.core.JobRunShell.run(JobRunShell.java:202) ~[?:?]
	... 1 more
I have tried it out without the timer and got no error.
rule "Pruebas varias"
  Time cron "0 0/3 * 1/1 * ? *"
  logInfo("RULE", "Pos0")
    logInfo("RULE", "Pos1")
    Temperatura_Programada.sendCommand((Temperatura_Nocturna_Mod.state as Number ).floatValue)
  else {
    logInfo("RULE", "Pos2")
    if (((Posicion_Valentin.state as Number).intValue == 3)) {
      logInfo("RULE", "Pos3")
    else {
      logInfo("RULE", "Pos4")
        logInfo("RULE", "Pos5")
        else {
          logInfo("RULE", "Pos6")
            logInfo("RULE", "Pos7")
          else {
            logInfo("RULE", "Pos8")
              logInfo("RULE", "Pos9")
            else {
              logInfo("RULE", "Pos10")
How can I debug it?
Thanks.
Edit: Strange. I just tried it changing the time (20:20) and now (20:25) I have no error on the log
Be aware that your ‘if’ expressions will fail if the Item has a NULL state.
