- Platform information:
Hardware: Xeon W-2275 128GB Ram
OS: Unraid 6.9.2 in docker container
Java Runtime Environment: The one in the docker container with the -e param for the log4 vuln
openHAB version: 3.1.1
Hello everyone,
I’m receiving this big chunk of error when I start my openhab instance. I know it connect to the mysql instance since when I query the database, I can see the new data in it.
2021-12-16 22:57:14.613 [ERROR] [org.knowm.yank.Yank ] - Error in SQL query!!!
java.sql.SQLException: Table 'openhab.Item47' doesn't exist Query: SELECT time, value FROM Item47 ORDER BY time DESC LIMIT 0,1 Parameters: []
at org.apache.commons.dbutils.AbstractQueryRunner.rethrow(AbstractQueryRunner.java:392) ~[bundleFile:?]
at org.apache.commons.dbutils.QueryRunner.query(QueryRunner.java:351) ~[bundleFile:?]
at org.apache.commons.dbutils.QueryRunner.query(QueryRunner.java:289) ~[bundleFile:?]
at org.knowm.yank.Yank.queryObjectArrays(Yank.java:578) [bundleFile:?]
at org.knowm.yank.Yank.queryObjectArrays(Yank.java:560) [bundleFile:?]
at org.openhab.persistence.jdbc.db.JdbcBaseDAO.doGetHistItemFilterQuery(JdbcBaseDAO.java:340) [bundleFile:?]
at org.openhab.persistence.jdbc.internal.JdbcMapper.getHistItemFilterQuery(JdbcMapper.java:169) [bundleFile:?]
at org.openhab.persistence.jdbc.internal.JdbcPersistenceService.query(JdbcPersistenceService.java:205) [bundleFile:?]
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
at org.openhab.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:154) [bundleFile:?]
at org.openhab.core.internal.common.Invocation.call(Invocation.java:52) [bundleFile:?]
2021-12-16 22:57:14.619 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'QueryablePersistenceService.query()' on 'org.openhab.persistence.jdbc.internal.JdbcPersistenceService@12e2fb26': null
at org.openhab.persistence.jdbc.db.JdbcBaseDAO.doGetHistItemFilterQuery(JdbcBaseDAO.java:344) ~[?:?]
at org.openhab.persistence.jdbc.internal.JdbcMapper.getHistItemFilterQuery(JdbcMapper.java:169) ~[?:?]
at org.openhab.persistence.jdbc.internal.JdbcPersistenceService.query(JdbcPersistenceService.java:205) ~[?:?]
2021-12-16 22:57:14.620 [ERROR] [ence.internal.PersistenceManagerImpl] - Exception occurred while querying persistence service 'jdbc': null
2021-12-16 22:57:14.680 [ERROR] [org.knowm.yank.Yank ] - Error in SQL query!!!
java.sql.SQLException: Table 'openhab.Item2' doesn't exist Query: SELECT time, value FROM Item2 ORDER BY time DESC LIMIT 0,1 Parameters: []
at jdk.internal.reflect.GeneratedMethodAccessor119.invoke(Unknown Source) ~[?:?]
2021-12-16 22:57:14.681 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'QueryablePersistenceService.query()' on 'org.openhab.persistence.jdbc.internal.JdbcPersistenceService@12e2fb26': null
2021-12-16 22:57:14.682 [ERROR] [ence.internal.PersistenceManagerImpl] - Exception occurred while querying persistence service 'jdbc': null
2021-12-16 22:57:14.717 [ERROR] [org.knowm.yank.Yank ] - Error in SQL query!!!
2021-12-16 22:57:14.718 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'QueryablePersistenceService.query()' on 'org.openhab.persistence.jdbc.internal.JdbcPersistenceService@12e2fb26': null
2021-12-16 22:57:14.719 [ERROR] [ence.internal.PersistenceManagerImpl] - Exception occurred while querying persistence service 'jdbc': null
2021-12-16 22:57:14.721 [ERROR] [org.knowm.yank.Yank ] - Error in SQL query!!!
2021-12-16 22:57:14.722 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'QueryablePersistenceService.query()' on 'org.openhab.persistence.jdbc.internal.JdbcPersistenceService@12e2fb26': null
2021-12-16 22:57:14.723 [ERROR] [ence.internal.PersistenceManagerImpl] - Exception occurred while querying persistence service 'jdbc': null
2021-12-16 22:57:19.582 [INFO ] [e.automation.internal.RuleEngineImpl] - Rule engine started.
2021-12-16 22:57:21.334 [ERROR] [al.handler.DSCAlarmBaseBridgeHandler] - Not Connected to the DSC Alarm!
2021-12-16 22:57:21.417 [WARN ] [ab.core.internal.events.EventHandler] - Creation of event failed, because one of the registered event factories has thrown an exception: Error invoking #valueOf(String) on class 'org.openhab.core.library.types.DateTimeType' with value '2-01-01T00:00:00.000-0500'.
java.lang.IllegalStateException: Error invoking #valueOf(String) on class 'org.openhab.core.library.types.DateTimeType' with value '2-01-01T00:00:00.000-0500'.
at org.openhab.core.items.events.ItemEventFactory.parseSimpleClassName(ItemEventFactory.java:190) ~[?:?]
at org.openhab.core.items.events.ItemEventFactory.parseType(ItemEventFactory.java:158) ~[?:?]
at org.openhab.core.items.events.ItemEventFactory.getState(ItemEventFactory.java:136) ~[?:?]
at org.openhab.core.items.events.ItemEventFactory.createStateEvent(ItemEventFactory.java:116) ~[?:?]
at org.openhab.core.items.events.ItemEventFactory.createEventByType(ItemEventFactory.java:80) ~[?:?]
at org.openhab.core.events.AbstractEventFactory.createEvent(AbstractEventFactory.java:53) ~[?:?]
at org.openhab.core.internal.events.EventHandler.createEvent(EventHandler.java:131) ~[?:?]
at org.openhab.core.internal.events.EventHandler.handleEvent(EventHandler.java:106) ~[?:?]
at org.openhab.core.internal.events.EventHandler.handleEvent(EventHandler.java:84) ~[?:?]
at org.openhab.core.internal.events.ThreadedEventHandler.lambda$0(ThreadedEventHandler.java:67) ~[?:?]
Caused by: java.lang.reflect.InvocationTargetException
at jdk.internal.reflect.GeneratedMethodAccessor101.invoke(Unknown Source) ~[?:?]
at org.openhab.core.items.events.ItemEventFactory.parseSimpleClassName(ItemEventFactory.java:181) ~[?:?]
... 10 more
Caused by: java.lang.IllegalArgumentException: 2-01-01T00:00:00.000-0500 is not in a valid format.
at org.openhab.core.library.types.DateTimeType.<init>(DateTimeType.java:112) ~[?:?]
at org.openhab.core.library.types.DateTimeType.valueOf(DateTimeType.java:123) ~[?:?]
... 10 more
Caused by: java.time.format.DateTimeParseException: Text '2-01-01T00T00:00:00:00:00.000-0500' could not be parsed at index 0
at java.time.format.DateTimeFormatter.parseResolved0(DateTimeFormatter.java:2046) ~[?:?]
at java.time.format.DateTimeFormatter.parse(DateTimeFormatter.java:1948) ~[?:?]
at java.time.LocalDateTime.parse(LocalDateTime.java:492) ~[?:?]
at org.openhab.core.library.types.DateTimeType.parse(DateTimeType.java:232) ~[?:?]
at org.openhab.core.library.types.DateTimeType.<init>(DateTimeType.java:106) ~[?:?]
... 10 more
Anyone have a clue on that?
Thank you
