I’m an absolut newbie here… Installed OPENHAB 2 from SD Card image, worked the manual and the tutorial completly through and most things I have basically understand. I just wanted to start with the bindings and my devices but have problems with binding install and uninstall… (already installed openhabian 3 times and everytime the same):
when I choose a binding and install it, the waiting circle never finishes and the binding page hang up. after I actualise it, then I see the binding is installed but not working properly. The same when I remove a binding… this is the log file, but I cant understand it…
2017-08-21 22:36:07.173 [INFO ] [basic.internal.servlet.WebAppServlet] - Stopped Basic UI2017-08-21 22:36:08.322 [ERROR] [org.eclipse.smarthome.io.rest.sse ] - FrameworkEvent ERROR - org.eclipse.smarthome.io.rest.sseorg.osgi.framework.BundleException: Exception in org.eclipse.smarthome.io.rest.sse.internal.SseActivator.start() of bundle org.eclipse.smarthome.io.rest.sse. at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:792)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:] at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:721)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:] at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:941)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:] at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:318)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:] at org.eclipse.osgi.container.Module.doStart(Module.java:571)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:] at org.eclipse.osgi.container.Module.start(Module.java:439)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:] at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:454)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:] at org.eclipse.osgi.container.ModuleContainer.applyDelta(ModuleContainer.java:717)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:] at org.eclipse.osgi.container.ModuleContainer.resolveAndApply(ModuleContainer.java:491)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:] at org.eclipse.osgi.container.ModuleContainer.resolve(ModuleContainer.java:437)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:] at org.eclipse.osgi.container.ModuleContainer.refresh(ModuleContainer.java:955)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:] at org.eclipse.osgi.container.ModuleContainer$ContainerWiring.dispatchEvent(ModuleContainer.java:1336)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:] at org.eclipse.osgi.container.ModuleContainer$ContainerWiring.dispatchEvent(ModuleContainer.java:1)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:] at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:] at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]Caused by: java.lang.LinkageError: ClassCastException: attempting to castbundleresource://21.fwk29049527/javax/ws/rs/ext/RuntimeDelegate.class to bundleresource://21.fwk29049527/javax/ws/rs/ext/RuntimeDelegate.class at javax.ws.rs.ext.RuntimeDelegate.findDelegate(RuntimeDelegate.java:146) at javax.ws.rs.ext.RuntimeDelegate.getInstance(RuntimeDelegate.java:120) at javax.ws.rs.core.MediaType.valueOf(MediaType.java:179) at org.glassfish.jersey.media.sse.SseFeature.(SseFeature.java:62) at org.eclipse.smarthome.io.rest.sse.internal.SseActivator.start(SseActivator.java:44) at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:771)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:] at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:] at java.security.AccessController.doPrivileged(Native Method)[:1.8.0_121] at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:764)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:] … 14 more2017-08-21 22:36:09.011 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app==> /var/log/openhab2/events.log <==2017-08-21 22:36:09.348 [ExtensionEvent ] - Extension ‘binding-chromecast’ has been installed.
Thank you very muchfor your help!
