Error on MCP23017 Openhab 3.3.0 - ( same on 3.4.0 )
Hi Guys, i try latest stable build of OH 3.3.0 , but probably MCP23017 add-on doesn’t work.
My config came from latest stable 2.5.12, on log MCP things are correct ONLINE but when i press relative SWITCH appear the error below.
Regards
Lorenzo
PI4J.VERSION : 2.0
WIRINGPI.VERSION : 2.46 ( i even tried 2.52 )
OpenJDK Runtime Environment Zulu11.60 ( i even try openjdk 11 )
2022-12-18 15:28:29.731 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.handleCommand()' on 'org.openhab.binding.mcp23017.internal.handler.Mcp23017Handler@222e6d': null
	at com.pi4j.io.gpio.impl.GpioControllerImpl.provisionPin(GpioControllerImpl.java:546) ~[?:?]
	at com.pi4j.io.gpio.impl.GpioControllerImpl.provisionDigitalOutputPin(GpioControllerImpl.java:720) ~[?:?]
	at org.openhab.binding.mcp23017.internal.handler.Mcp23017PinStateHolder.initializeOutputPin(Mcp23017PinStateHolder.java:75) ~[?:?]
	at org.openhab.binding.mcp23017.internal.handler.Mcp23017PinStateHolder.getOutputPin(Mcp23017PinStateHolder.java:63) ~[?:?]
	at org.openhab.binding.mcp23017.internal.handler.Mcp23017Handler.handleOutputCommand(Mcp23017Handler.java:112) ~[?:?]
	at org.openhab.binding.mcp23017.internal.handler.Mcp23017Handler.handleCommand(Mcp23017Handler.java:83) ~[?:?]
	at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
	at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
	at org.openhab.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:154) [bundleFile:?]
	at org.openhab.core.internal.common.InvocationHandlerSync.invoke(InvocationHandlerSync.java:59) [bundleFile:?]
	at com.sun.proxy.$Proxy556.handleCommand(Unknown Source) [?:?]
	at org.openhab.core.thing.internal.profiles.ProfileCallbackImpl.handleCommand(ProfileCallbackImpl.java:80) [bundleFile:?]
	at org.openhab.core.thing.internal.profiles.SystemDefaultProfile.onCommandFromItem(SystemDefaultProfile.java:48) [bundleFile:?]
	at org.openhab.core.internal.common.Invocation.call(Invocation.java:52) [bundleFile:?]
Autosolved…
openhab and openhabian users are just same on my mind…
A simple command resolve my issue.
# usermod -a -G i2c openhab
