Error on mqtt 2.5.2
with openhab-addons-2.5.2-SNAPSHOT.kar the mqtt binding will not work.
see atteched fileNeues Textdokument (2).txt (4.3 KB)
Don’t do that. You prevent anyone else encountering a similar error from finding your post with a search.
what du you mean? what is wrong?
Please post a description of your problem, use code fences to include error messages.
It’s in your own interest to make it easy for people to help you.
You attached some file instead of adding information in the post. I will not download the file to identify what your problem is.
This. Having the log file is great if you find someone that wants to dig into the problem deeply, but no one is likely to do that digging without a brief description of this problem that helps them decide whether their effort would be productive.
If I use the 2.5.1 add-ons, all is OK. If ich use the 2.5.2 mqtt does not work. In the log file are the error messages.
paste the error inline, with code fences, so that people can find it, look at it and respond directly without downloading a file:
2020-02-15 21:07:59.342 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.initialize()' on 'org.openhab.binding.mqtt.generic.internal.handler.GenericMQTTThingHandler@12d58bd': org.openhab.binding.mqtt.generic.values.Value.createStateDescription(Ljava/lang/String;Z)Lorg/eclipse/smarthome/core/types/StateDescription;
java.lang.NoSuchMethodError: org.openhab.binding.mqtt.generic.values.Value.createStateDescription(Ljava/lang/String;Z)Lorg/eclipse/smarthome/core/types/StateDescription;
        at org.openhab.binding.mqtt.generic.internal.handler.GenericMQTTThingHandler.initialize(GenericMQTTThingHandler.java:156) ~[?:?]
        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:1.8.0_152]
        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:1.8.0_152]
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_152]
        at java.lang.reflect.Method.invoke(Method.java:498) ~[?:1.8.0_152]
        at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:152) [bundleFile:?]
        at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:52) [bundleFile:?]
        at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_152]
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_152]
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_152]
        at java.lang.Thread.run(Thread.java:748) [?:1.8.0_152]
2020-02-15 21:07:59.351 [ERROR] [core.thing.internal.ThingManagerImpl] - Exception occurred while initializing handler of thing 'mqtt:topic:meinBroker:wohnwagen': org.openhab.binding.mqtt.generic.values.Value.createStateDescription(Ljava/lang/String;Z)Lorg/eclipse/smarthome/core/types/StateDescription;
2020-02-15 21:08:59.289 [WARN ] [nhab.binding.mqtt.action.MQTTActions] - MQTT Action service ThingHandler connection is null!
2020-02-15 21:09:59.292 [WARN ] [nhab.binding.mqtt.action.MQTTActions] - MQTT Action service ThingHandler connection is null!
2020-02-15 21:10:20.011 [INFO ] [.eclipse.smarthome.model.script.info] - Bar Status senden
2020-02-15 21:10:20.024 [WARN ] [nhab.binding.mqtt.action.MQTTActions] - MQTT Action service ThingHandler connection is null!
2020-02-15 21:10:20.029 [WARN ] [nhab.binding.mqtt.action.MQTTActions] - MQTT Action service ThingHandler connection is null!
2020-02-15 21:11:59.302 [WARN ] [nhab.binding.mqtt.action.MQTTActions] - MQTT Action service ThingHandler connection is null!
2020-02-15 21:12:07.553 [WARN ] [nhab.binding.mqtt.action.MQTTActions] - MQTT Action service ThingHandler connection is null!
2020-02-15 21:12:16.868 [WARN ] [nhab.binding.mqtt.action.MQTTActions] - MQTT Action service ThingHandler connection is null!
2020-02-15 21:15:59.319 [WARN ] [nhab.binding.mqtt.action.MQTTActions] - MQTT Action service ThingHandler connection is null!
