Does anybody have an idea what I’m doing wrong? I am on openHAB2 latest unstable build from apt repository on Debian (x86_64). Thanks a lot in advance!
I have this error sometimes when using Eclipse SmartHome Designer. Edit the persistence file via
vim
or your preferred editor, directly on Raspberry, and save it.
I my cases the error just vanishes, and also does not reappear when doing the next changes via SmartHome Designer again.
I can’t confirm that it works but I’m not getting the same “Configuration model ‘rrd4j.persist’ has errors, therefore ignoring it: [1,1]: mismatched input ‘’ expecting ‘Strategies’” error nor any other errors, so maybe
I discovered that using an other editor helped. I moved from working with notepad ++ to microsoft visual studio and then I didnt see the error anymore.
I was questioning the “microsofg visual studio”, sincd the actually suggested editor for OH is “visual studio code”. Sounds similar but it isn’t!
The later has (with the openHAB extension) code highlighting etc.!
