[ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule ‘heat living’: An error occurred during the script execution: org/joda/time/DateTime
My Rule:
rule "heat living"
Item Temp_kitchen received update or Item Temp_kitchen_setpoint received command
var Number setValue = Temp_kitchen.state as Number
var Number tarValue = Temp_kitchen_setpoint.state as Number
if (setValue.floatValue >= tarValue.floatValue)
{sendCommand(acc_living, OFF)}
else
{sendCommand(acc_living, ON)}
Another thought, if this happened immediately after updating, try to restart OH2 once or twice (giving it a few minutes in between), not sure whether you are on the stable or the snapshot version, but I have had seemingly random errors after updates for quite some time (on snapshot version though);
I mean, have you checked that there is no other rule with the same name?
Else, you can try to change/reduce the statements in when and/or then, to check if the error changed also.
