halloween
(Hallo Ween)
January 18, 2018, 7:03am
1
Hi, my openhab 2.3 snapshot runs on a debian server.
Since few days i get the following error, when trying to make an apt-get upgrade:
W: GPG-Fehler: http://repo.mosquitto.org jessie InRelease: Die folgenden Signaturen waren ungültig: KEYEXPIRED 1515017477 KEYEXPIRED 1515017477 KEYEXPIRED 1515017477
Here is the exact same problem described with a way to solve this, but i lack of linux experiance to do that…
https://www.raspberrypi.org/forums/viewtopic.php?t=201598
Please can you tell me, how i have to do this?
–> remove the repo and use the latest in jessie or upgrade to stretch
I already made this:
sudo apt-get update
sudo apt-get upgrade
wget http://repo.mosquitto.org/debian/mosquitto-repo.gpg.key
sudo apt-key add mosquitto-repo.gpg.key
reboot
///again
apt-get-update / upgrade
/// then i made:
sudo apt-get dist-upgrade
reboot
/// but still the same errors
halloween
(Hallo Ween)
February 26, 2018, 7:51am
2
Is there anybody, who can help me? The error still exists…
My openhab and mosquitto is installed on my debian jessie server.
KaNe
(Kai)
March 4, 2018, 11:17am
3
try this:
$ apt-key list
Output:
/etc/apt/trusted.gpg
pub 4096R/30993623 2013-01-04 [verfallen: 2018-01-03]
uid Mosquitto Apt Repository <repo@mosquitto.org>
keyID from mosquitto is "30993623"
After this:
sudo apt-key del 30993623
key removed.
Now get the new key and store it:
no reboot needed
Now you can do apt-get update again.
halloween
(Hallo Ween)
March 4, 2018, 3:08pm
4
Thank you. Now id did something when i made apt-get update and upgrade.
But the error still apears, when i make apt-get update again. Even after reboots.
KaNe
(Kai)
March 6, 2018, 9:00pm
5
perhaps you have more than 1 key, which isn’t valid anymore…read the log carefully.
halloween
(Hallo Ween)
March 7, 2018, 12:45pm
6
I don´t need mosquitto (MQTT Server). I installed it only fore testing some time ago.
How can i completely remove the mosquitto-files including all other installed things (in german: inklusive aller damals mitinstallierten und dann nicht mehr benötigten Abhängigkeiten)?
halloween
(Hallo Ween)
March 7, 2018, 2:14pm
7
I made
apt-get remove mosquitto
and after that
apt-get autoremove
to remove the dependencies, which are not needed anymore.
After that i removed the repo key also like described from you a few posts above.
Now i get this when i make apt-get update
W: GPG-Fehler: http://repo.mosquitto.org jessie InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 61611AE430993623
halloween
(Hallo Ween)
March 7, 2018, 2:26pm
8
I found a thread in the internet where this was descripbed to do:
gpg --keyserver keyserver.ubuntu.com --recv 61611AE430993623
gpg --export --armor 61611AE430993623 | sudo apt-key add -
After that i made apt-get update and the error is gone.
But now the mosquitto-repo-list is there again when i make apt-get keylist.
Is this ok or should i remove the mosquitto-repo?
How can i do this?
I have no clue, what this commands did… I´m a linux beginner.
