I am at a friend of mine and we migrated his openHAB 1.x to 2.3 a few weeks back.
Its running on raspbian.
We now wanted to install the mqtt binding, but it does not work.
So far the installation is very small.
Only ntp, mail and owserver2 are installed via config files.
The problem seems to be this WARN:
2018-07-18 23:54:01.842 [WARN ] [raf.features.internal.osgi.Activator] - Error starting activator
java.io.IOException: Unexpected end of input at 1:1
at org.apache.karaf.features.internal.util.JsonReader.error(JsonReader.java:337) [10:org.apache.karaf.features.core:4.1
at org.apache.karaf.features.internal.util.JsonReader.expected(JsonReader.java:331) [10:org.apache.karaf.features.core:
at org.apache.karaf.features.internal.util.JsonReader.readValue(JsonReader.java:93) [10:org.apache.karaf.features.core:
at org.apache.karaf.features.internal.util.JsonReader.parse(JsonReader.java:58) [10:org.apache.karaf.features.core:4.1.
at org.apache.karaf.features.internal.util.JsonReader.read(JsonReader.java:52) [10:org.apache.karaf.features.core:4.1.5
at org.apache.karaf.features.internal.region.DigraphHelper.readDigraph(DigraphHelper.java:90) [10:org.apache.karaf.feat
re:4.1.5]
at org.apache.karaf.features.internal.region.DigraphHelper.loadDigraph(DigraphHelper.java:70) [10:org.apache.karaf.feat
re:4.1.5]
at org.apache.karaf.features.internal.osgi.Activator.doStart(Activator.java:131) [10:org.apache.karaf.features.core:4.1
at org.apache.karaf.util.tracker.BaseActivator.run(BaseActivator.java:242) [10:org.apache.karaf.features.core:4.1.5]
In the karaf console we cannot use the feature
command which at least works on my v2.1 installation.
Paper UI does not show the Addons
menu.
We cleared /var/lib/openhab2/cache
and /var/lib/openhab2/tmp
We deleted the json-Files wich were empty anyway.
Any idea what might be the cause for this issue?
