Error "Switching to branch when running "opehanbian-config"
Since a recent update I keep getting the error “FAILED” when the script tries to change to what I assume is the current branch. I’ve tried to find the error, but keep failing. Any hints of where to look would be greatly appreciated. I’m guessing that it might be that my openhabian.conf is missing a line containg information about the current version
2020-06-21_16:50:52_PDT [openHABian] Checking for root privileges… OK
2020-06-21_16:50:52_PDT [openHABian] Loading configuration file ‘/etc/openhabian.conf’… OK
2020-06-21_16:50:52_PDT [openHABian] openHABian configuration tool version: [stable]v1.5-644(e01719a)
2020-06-21_16:50:53_PDT [openHABian] Checking for changes in origin branch HEAD … OK
2020-06-21_16:52:42_PDT [openHABian] Switching to branch … fatal: empty string is not a valid pathspec. please use . instead if you meant to match all paths
FAILED
And with debug set to maximum:
  • echo -n '2020-06-21_17:23:34_PDT [openHABian] Switching to branch … ’
    2020-06-21_17:23:34_PDT [openHABian] Switching to branch … + git -C /opt/openhabian checkout --quiet ‘’
  • FAILED=1
  • echo FAILED
    FAILED
  • return 0
Ira
Are there branch= and repositoryurl= lines in /etc/openhabian.conf ?
Try
cd /opt/openhabian
git status
Then
git checkout stable
(or master)
There are no branch= or respsitoryurl= lines in openhabian.conf.
I would add them if I had an idea what they should look like.
git claims to be up to date on master with no issues
Thank you so much for responding.
Ira
You can add them but that is not your problem. They don’t have to be there for git / openhabian-config to work.
repositoryurl=https://github.com/openhab/openhabian.git
clonebranch=stable
What’s the output of the commands I asked you to execute ?
Sorry, I said it was all OK but didn’t post it, here it is:
[00:34:04] openhabian@openhab:/opt/openhabian$ git status On branch master Your branch is up to date with 'origin/master'.
nothing to commit, working tree clean
[00:34:31] openhabian@openhab:/opt/openhabian$ sudo git checkout master
[sudo] password for openhabian:
Already on ‘master’
Your branch is up to date with ‘origin/master’.
And again, thanks so much for helping.
Ira
adding the lines:
clonebranch=master
got rid of the error message which makes me very happy.
Thanks, Ira
