[ERROR] [ternal.service.BootFeaturesInstaller] - Error installing boot features
Dear all,
since yesterday I am facing the issue, that OH3 Frontend does not work anymore. I would very much appreciate any kind of hints or help. Thank you
If I restart the RPi or use sudo systemctl restart openhab
follwoing entries are logged:
2021-04-29 17:55:35.142 [ERROR] [ternal.service.BootFeaturesInstaller] - Error installing boot features
org.apache.felix.resolver.reason.ReasonException: Unable to resolve root: missing requirement [root] osgi.identity; osgi.identity=openhab-runtime-ui; type=karaf.feature; version="[3.1.0.M3,3.1.0.M3]"; filter:="(&(osgi.identity=openhab-runtime-ui)(type=karaf.feature)(version>=3.1.0.M3)(version<=3.1.0.M3))" [caused by: Unable to resolve openhab-runtime-ui/3.1.0.M3: missing requirement [openhab-runtime-ui/3.1.0.M3] osgi.identity; osgi.identity=org.openhab.ui; type=osgi.bundle; version="[3.1.0.M3,3.1.0.M3]"; resolution:=mandatory [caused by: Unable to resolve org.openhab.ui/3.1.0.M3: missing requirement [org.openhab.ui/3.1.0.M3] osgi.wiring.package; filter:="(osgi.wiring.package=org.openhab.core.net)" [caused by: Unable to resolve org.openhab.core/3.1.0.M3: missing requirement [org.openhab.core/3.1.0.M3] osgi.ee; filter:="(&(osgi.ee=JavaSE)(version=11))"]]]
at org.apache.felix.resolver.Candidates$MissingRequirementError.toException(Candidates.java:1343) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.apache.felix.resolver.ResolverImpl.doResolve(ResolverImpl.java:392) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.apache.felix.resolver.ResolverImpl.resolve(ResolverImpl.java:378) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.apache.felix.resolver.ResolverImpl.resolve(ResolverImpl.java:332) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.apache.karaf.features.internal.region.SubsystemResolver.resolve(SubsystemResolver.java:257) ~[?:?]
at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:393) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.doProvision(FeaturesServiceImpl.java:1062) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.lambda$doProvisionInThread$13(FeaturesServiceImpl.java:998) ~[?:?]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_212]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_212]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_212]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_212]
Caused by: org.apache.felix.resolver.reason.ReasonException: Unable to resolve openhab-runtime-ui/3.1.0.M3: missing requirement [openhab-runtime-ui/3.1.0.M3] osgi.identity; osgi.identity=org.openhab.ui; type=osgi.bundle; version="[3.1.0.M3,3.1.0.M3]"; resolution:=mandatory [caused by: Unable to resolve org.openhab.ui/3.1.0.M3: missing requirement [org.openhab.ui/3.1.0.M3] osgi.wiring.package; filter:="(osgi.wiring.package=org.openhab.core.net)" [caused by: Unable to resolve org.openhab.core/3.1.0.M3: missing requirement [org.openhab.core/3.1.0.M3] osgi.ee; filter:="(&(osgi.ee=JavaSE)(version=11))"]]
... 12 more
Caused by: org.apache.felix.resolver.reason.ReasonException: Unable to resolve org.openhab.ui/3.1.0.M3: missing requirement [org.openhab.ui/3.1.0.M3] osgi.wiring.package; filter:="(osgi.wiring.package=org.openhab.core.net)" [caused by: Unable to resolve org.openhab.core/3.1.0.M3: missing requirement [org.openhab.core/3.1.0.M3] osgi.ee; filter:="(&(osgi.ee=JavaSE)(version=11))"]
... 12 more
Caused by: org.apache.felix.resolver.reason.ReasonException: Unable to resolve org.openhab.core/3.1.0.M3: missing requirement [org.openhab.core/3.1.0.M3] osgi.ee; filter:="(&(osgi.ee=JavaSE)(version=11))"
... 12 more
  • Platform information:
    • Hardware: RPi4
    • Java Runtime Environment: openjdk version “1.8.0_212”
      OpenJDK Runtime Environment (build 1.8.0_212-8u212-b01-1+rpi1-b01)
      OpenJDK Client VM (build 25.212-b01, mixed mode)
    • openHAB version: OH3
Please use Java 11 as documented in the requirements:
@wborn Thanks a lot for that hint. It solved the problem. However it is a bit strange. I installed OH 3 beginning of the year. No problems until this week. Hence I assuemd that Java version should not be the issue. Unfortunatelly it was.
Hello togehter,
I have nearly the same, but the JAVA 11 update is not my problem, I assume…
What I have done:
  1. I have created an Backup from my Running OpenHab V3.1 (Openhabian)
  2. Then I installed a complete new Image of OpenHab V3.2 (openHABian v1.7.2 intalled Stable version).
  3. I installed my Backup into the new OpenHab V3.2. (By sudo openhabian-config)
→ OpenHab does not start anymore…
I have done the same now two times, with two different Backups → the same result.
Has someone an Idea?
2022-02-09 19:23:59.973 [ERROR] [ternal.service.BootFeaturesInstaller] - Error installing boot features
org.apache.karaf.features.internal.util.MultiException: Error:
	Error downloading mvn:org.ops4j.pax.logging/pax-logging-api/2.0.12
	Error downloading mvn:org.ops4j.pax.logging/pax-logging-log4j2/2.0.12
	at org.apache.karaf.features.internal.download.impl.MavenDownloadManager$MavenDownloader.<init>(MavenDownloadManager.java:91) ~[?:?]
	at org.apache.karaf.features.internal.download.impl.MavenDownloadManager.createDownloader(MavenDownloadManager.java:72) ~[?:?]
	at org.apache.karaf.features.internal.region.Subsystem.downloadBundles(Subsystem.java:457) ~[?:?]
	at org.apache.karaf.features.internal.region.Subsystem.downloadBundles(Subsystem.java:452) ~[?:?]
	at org.apache.karaf.features.internal.region.SubsystemResolver.resolve(SubsystemResolver.java:224) ~[?:?]
	at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:399) ~[?:?]
	at org.apache.karaf.features.internal.service.FeaturesServiceImpl.doProvision(FeaturesServiceImpl.java:1069) ~[?:?]
	at org.apache.karaf.features.internal.service.FeaturesServiceImpl.lambda$doProvisionInThread$13(FeaturesServiceImpl.java:1004) ~[?:?]
	Suppressed: java.io.IOException: Error downloading mvn:org.ops4j.pax.logging/pax-logging-api/2.0.12
		at org.apache.karaf.features.internal.download.impl.AbstractRetryableDownloadTask.run(AbstractRetryableDownloadTask.java:77) ~[?:?]
	Caused by: java.io.IOException: Error resolving artifact org.ops4j.pax.logging:pax-logging-api:jar:2.0.12: [Could not find artifact org.ops4j.pax.logging:pax-logging-api:jar:2.0.12 in openhab (https://openhab.jfrog.io/openhab/libs-release/)]
		at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.configureIOException(AetherBasedResolver.java:803) ~[?:?]
		at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:774) ~[?:?]
		at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:657) ~[?:?]
		at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:598) ~[?:?]
		at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:565) ~[?:?]
		at org.apache.karaf.features.internal.download.impl.MavenDownloadTask.download(MavenDownloadTask.java:52) ~[?:?]
		at org.apache.karaf.features.internal.download.impl.AbstractRetryableDownloadTask.run(AbstractRetryableDownloadTask.java:60) ~[?:?]
		... 6 more
		Suppressed: shaded.org.eclipse.aether.transfer.ArtifactNotFoundException: Could not find artifact org.ops4j.pax.logging:pax-logging-api:jar:2.0.12 in openhab (https://openhab.jfrog.io/openhab/libs-release/)
			at shaded.org.eclipse.aether.connector.basic.ArtifactTransportListener.transferFailed(ArtifactTransportListener.java:48) ~[?:?]
			at shaded.org.eclipse.aether.connector.basic.BasicRepositoryConnector$TaskRunner.run(BasicRepositoryConnector.java:368) ~[?:?]
			at shaded.org.eclipse.aether.util.concurrency.RunnableErrorForwarder$1.run(RunnableErrorForwarder.java:75) ~[?:?]
			at shaded.org.eclipse.aether.connector.basic.BasicRepositoryConnector$DirectExecutor.execute(BasicRepositoryConnector.java:642) ~[?:?]
			at shaded.org.eclipse.aether.connector.basic.BasicRepositoryConnector.get(BasicRepositoryConnector.java:262) ~[?:?]
			at shaded.org.eclipse.aether.internal.impl.DefaultArtifactResolver.performDownloads(DefaultArtifactResolver.java:489) ~[?:?]
			at shaded.org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolve(DefaultArtifactResolver.java:390) ~[?:?]
			at shaded.org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolveArtifacts(DefaultArtifactResolver.java:215) ~[?:?]
			at shaded.org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolveArtifact(DefaultArtifactResolver.java:192) ~[?:?]
			at shaded.org.eclipse.aether.internal.impl.DefaultRepositorySystem.resolveArtifact(DefaultRepositorySystem.java:247) ~[?:?]
			at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:767) ~[?:?]
	Caused by: shaded.org.eclipse.aether.resolution.ArtifactResolutionException: Error resolving artifact org.ops4j.pax.logging:pax-logging-api:jar:2.0.12
		at shaded.org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolve(DefaultArtifactResolver.java:413) ~[?:?]
		... 6 more
	Suppressed: java.io.IOException: Error downloading mvn:org.ops4j.pax.logging/pax-logging-log4j2/2.0.12
	Caused by: java.io.IOException: Error resolving artifact org.ops4j.pax.logging:pax-logging-log4j2:jar:2.0.12: [Could not find artifact org.ops4j.pax.logging:pax-logging-log4j2:jar:2.0.12 in openhab (https://openhab.jfrog.io/openhab/libs-release/)]
		... 6 more
		Suppressed: shaded.org.eclipse.aether.transfer.ArtifactNotFoundException: Could not find artifact org.ops4j.pax.logging:pax-logging-log4j2:jar:2.0.12 in openhab (https://openhab.jfrog.io/openhab/libs-release/)
	Caused by: shaded.org.eclipse.aether.resolution.ArtifactResolutionException: Error resolving artifact org.ops4j.pax.logging:pax-logging-log4j2:jar:2.0.12
		... 6 more
I have the exact same issue. Hopefully someone has an idea how to fix.
@Curtis
I’ve found the Problem:
It is not allowed to install the Backup to a different Version…
  1. Install your old version of openhab again. Or do an downgrade (Downgrade from 3.1.0 to 3.0.1 )
  2. Then install our Backup
  3. Now you can do an Upgrade by the sudo openhabian-config command
Thanks very much @SmartHome4all that worked!
