I have carried out these instructions but in VScode I still cant save the edits Im making in the openhab directory.
I can log in via SSH and make the changes then view in VScode to see if it gives me any errors. It works but it kinds of defeats the purpose.
Do you have any idea what it might be? In VScode I also keep getting the error that it cant connect to the rest API which I tried resolving using some instructions on this forum but it also didnt work unfortunately.
when trying to save an edit, VScode shows me an error ‘failed to save, retry as admin’ which then brings up a windows pop up window. So I dont tell if this is trying to escalate permissions in windows or on the pi??
also, after changing the permissions the files and folders were highlighted in yellow when I look in the terminal so I assume the permissions are different than before.
Thats only the folders, not the content of one folder. Means the files you want to edit. Please look in the items folder and list it.
The drwxrwsr-x are the user rights and they are as they schould.
You have to adjust the file setting for every new created file of openhab.
When you install a binding the new cfg will not have the file permisision to be access by pi.
So if this error occurs look at the file permission of this file. and change it accordingly.
Please look if the user pi is also in the group openhab, and restart!
groups
pi adm dialout cdrom sudo audio video plugdev games users input netdev openhab gpio i2c spi
rule "HWS Demand Check"
Time cron "0 * * ? * *"
var Temp = Temperature_HWS_state as Number
var Setpoint = HWS_Setpoint.state as Number
var Deadband = HWS_Deadband.state as Number // (I could see how you get your deadband value from so I assumed an Number Item)
if(Temp > Setpoint){
logInfo("HWS Demand","HWS Temp is HIGH"+Temp.toString() +"/"+ Setpoint.toString())
if(HWS_Demand.state != OFF){
HWS_Demand.sendCommand(OFF)
logInfo("HWS Status","Demand - "+Heating_Demand.state.toString())
}else if(Temp < (Setpoint + Deadband)){
logInfo("HWS Demand","HWS Temp is LOW"+Temp.toString()+"/"+Setpoint.toString()+"/"+Deadband.toString())
if(HWS_Demand.state != ON){
HWS_Demand.sendCommand(ON)
logInfo("HWS Status","Demand - "+Heating_Demand.state)
pi@raspberrypi:/etc/openhab2 $ ls -l items
total 24
-rwxrwsr-x 1 root root 108 Mar 4 20:16 boiler.items
-rwxrwsr-x 1 root root 1324 Mar 4 20:26 mqtt.items
-rwxrwsr-x 1 root root 1312 Mar 4 20:23 occupancy.items
-rwxrwsr-x 1 root root 767 Mar 10 10:28 presence.items
-rwxrwxr-x 1 openhab openhab 227 Mar 9 19:54 readme.txt
-rwxrwsr-x 1 root root 904 Mar 10 10:34 setpoints.items
and for comparison, the rules files where I have added new files without updating the persmissions
pi@raspberrypi:/etc/openhab2 $ ls -l rules
total 36
-rwxrwsr-x 1 root root 2473 Mar 4 20:10 boiler.rules
-rwxrwsr-x 1 root root 3421 Feb 26 14:41 heatingdemands.rules
-rw-r--r-- 1 root openhab 2055 Mar 9 21:33 heating.rules
-rwxrwsr-x 1 root root 5370 Feb 26 14:22 occupancy.rules
-rwxrwsr-x 1 root root 356 Jan 26 21:40 ovr.rules
-rwxrwsr-x 1 root root 876 Feb 6 13:49 presence.rules
-rwxrwsr-x 1 openhab openhab 222 Jun 28 2017 readme.txt
-rw-r--r-- 1 root openhab 754 Mar 10 11:07 setpoints.rules
and here is the pi groups
pi@raspberrypi:/etc/openhab2 $ groups pi
pi : pi adm dialout cdrom sudo audio video plugdev games users input netdev spi i2c gpio openhab
Worth noting too, I log in with the pi user account in SFTP net drive. I see owner of the file is root, does that mean that pi isnt being giving root access through SFTP? I cant see an option to escalate that persimission in SFTP. So next option, would be to always give the pi user root access?
changing the files/folders to be owned by openhab, and the pi user is in the openhab group, by logging in with pi in SFTP it is given the permissions to read/write/execute etc. Whereas before, the files/folders were owned by root, so pi did not inherit those permissions.
I am able to now make changes etc, but if I create a new file, I still need to SSH into the pi and update the permissions to be able to modify it in VScode.
One thing that I dont understand (but I dont think is important), when I change the permissions as described above
sudo chmod -R 2775 /etc/openhab2
The files are all highlighted in yellow.
When I changed the owner, the text was green, which I believe it what happens if you make a file executable??
after adding a new file and doing the sudo chmod business again, they are highlighted yellow again.
Regardless, this works for VScode. so maybe its necessary.
